B1550-HST clutch
zmanfj40
US
Clutch grenaded. Should I replace the pressure plate as well?
Sent from my SM-G930V using Tapatalk
6,541
You should replace 5 parts while your in there.
The throw-out bearing, the pressure plate, the clutch disk, the pilot bearing and the pilot bearing seal. ;)
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
And if you want to go further, consider the engine rear main seal, and the input shaft, as it may be a bit flogged by the looks of the clutch center spline.
zmanfj40
US
Replacing all parts definitely. The wsm says to inspect the plate surface for scratches or cracks so ...yeah ...the input shaft was fine though. The wsm download has been a huge help.
zmanfj40
US
Item description for parts kit says release bearing. Is that the throwout or pilot bearing?
6,541
Release bearing is the throw out bearing.
Clutch disk P/N 67980-13400
Pressure plate P/N 67211-13300
Throw out /Release bearing P/N 67311-13320
Pilot Bearing P/N 66621-14120
Pilot seal P/N 09400-14247
zmanfj40
US
Got all my parts ,thanks for the pn's very helpful. What is the correct removal procedure of the pilot bushing? That thing is stubborn! I've tried using the inner hole and pulling with a custom hook tool. About ready to just use excessive force! TIA.
5,644
zmanfj40, make a wooden dowel that "just" fits into the existing bearing. You can make this from an existing piece of wood you may have, or use a piece of a broom handle and work the OD down on your bench grinder. Make it so it just barely fits into your new bearing.
Then fill the hole inside the bearing with grease from your grease gun. Put your dowel in the hole and tap it with a hammer. You may have to do this process a couple of times(and add some grease) but it will come out.
Hydraulic pressure at its best!!
5,391
Wow 'Cat - - that there is fascinating!
Ingenious is the other word that comes to mind....
The picture helped me, hope it helps the OP as much..
'Nuf said, don't want to get the thread off-track....
helomech
527
East Texas
Serious question. What would cause this in HST tractor? I only use my clutch to start the thing. Seems to me, the clutch should last forever.
zmanfj40
US
Wondered the same question myself until I only had three bolts left holding the case to the engine. The PO had neglected to tighten the loader subframe bolts causing flex at the case and shearing bolts, the output shaft destroyed the weakest link (clutch). That's what I concluded. This tractor has been a great learning tool for repairs and system functions that I never cared to know about! [emoji16]
helomech
527
East Texas
Dang, sorry that sucks.
