Taking what I call a stump jumper off a brush hog
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
How do I get this off I have the nut off but can't get it to move off the splines
1970cs
1,124
Grand Ledge
What manufacturer? I would like to think that most companies have a special T- bar puller for that purpose.
Pat
rentthis
1,009
25
summerville,sc
If you can't get a nut under the existing holes, you could drill and tap 2 holes to accommodate a shorter T-bar puller. There appears to be plenty of "meat" there. Be sure to flood it good with penetrating oil first.
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
Called LMC and asked them how they take the stump jumper off. They said to use two metal wedges and be sure not to use any heat.
tinkerwitheverything
bx2370-1
Jun 3, 2015
319
73
Manitoba
I,ve used a hyralic jack and a piece of chain. Set the jack on the spindle use the chain to span over the jack and bolt the chain into the place where the bolts for the blades go thru. once you have it mounted etc: jack up the jack and it'll work like a puller.BTW put the nut on first and have the top of the nut flush to the top of tthe bolt to protect the threads.
1,492
You may want to get it on its side and chained to something (tree?) so you have better access. It is difficult to get penetrating oil into the joint without gravity to help. I don't think you can get to the topside to get a spray there but you might try to see if you can get a shot onto the shaft and let it run down. It won't be fast or easy and some people resort to just cutting it off and replacing it (if you can get a new part).
Why do you want it off?
billrigsby
Mar 17, 2015
1,023
208
Florissant CO USA 8213'
www.facebook.com
What Russell said :rolleyes:
That is what I did, I should have mentioned that :p
Also a hell of a lot easier to work on upright.
And once it is off, and going back on,
slather the hell out of that spline with anti-seize. :D
You will NOT regret it. :D
Good question? my guess is general "serious" maintenance or resto.
I like to be sure things are "tear-down-able" (is that a word? :confused:) early on
so if I need to fix something it is not an issue later on....
Tooo much time on my hands ! :eek:
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
It is cracked I was going to take it off and take it to work and weld it up. But I think I'm going to weld it on the hog. It won't take much so I'm not worried about getting it to hot.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
I had a truck come in the quarry once with the windshield busted out, the rear of the cab torn open and the blade was sticking in the front of his dump trailer. Blade broke off one of the counties side arm mower. Only thing saved the driver is it went thru the right side of the cab.
I don't trust a cracked stump jumper. Think of the weight and speed of the blades and how much damage they could do if it breaks. I would look at replacing it but that's just me.
