I have an L3301HST with a BH77 backhoe. When the 3-point hitch is lowered and the lower arms are spread apart to the normal operating position for my attachments, the bar through the middle of the leveling link bumps into the backhoe subframe, preventing the link from turning:
This causes a number of headaches when mounting attachments, or adjusting ones that are already mounted. Sometimes I can lift the arms up to avoid the interference, but that's not an option while adjusting the arms to get an attachment hooked up, or if I need to lower an attachment to take pressure off the link so it can be turned.
I'm considering adding rear hydraulics someday, so eventually I might eliminate the problem with a hydraulic leveling link. But for now, have any of y'all come up with good workarounds for this kind of problem?
Another related headache that I experienced is that when I mount my PD15 post hole digger, the lower arms don't spread far enough apart to mount it without using a hammer if the digger is even the tiniest bit out of the perfect position... which it always is, of course! I have the telescopic stabilizer option, but I wish that I also had those telescopic lower link ends that are offered on the Grand L60 series.
