How many of you use steering wheel spinners on your tractor(s)?
2,976
Hokie in post #6 in the photo, the spinner looks like it is on the wheel. But the spokes look very big. Maybe the spinner would not fit onto the spoke. I just ordered a Kubota one($$$) now I read the Kubota one is junk. But my question is whats the issue with clamping it to the wheel if it won't fit the spoke ??
The reason it was called a suicide knob is because many placed it on the OUTSIDE ring of the wheel - when cornering (tractor or car) the wheel could spin back quickly and get your hand/wrist etc..... by placing on the spoke and using the hand on the outside of the wheel - problem is eliminated.
On my tractors......I'd say the fastest I am turning is going to be about 3 mph, the spinning rate of my steering wheel is not going to do much, I will tell you - hitting a root or dip in the front end, will tell the hand to hold on tight!
That is not my spinner in #6 - here is mine - an Amazon product :
https://www.amazon.com/WSV125OR-Sha...5022390&sr=8-6&keywords=tractor+wheel+spinner
problem #1 - the bolts are not long enough! IT will NOT fit on the spokes!
SO - you need a pair of longer bolts and a little shim material - I used a piece of hard rubber so not to damage the wide spoke on the wheel, I think I had to bang the backing plate a bit too!:)
7,365
I always thought is was called a suicide knob because in case of a collision it may be what your chest smacks hard (in a motor vehicle).
I have never had a steering wheel on a tractor ever spin out of control in a turn, or hitting a hole, plow furrow or anything else. Just fortunate I guess.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
May be a difference in design. My L3000 has power steering but not hydrostatic. Steering wheel doesn't drift around on it at all.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,276
178
Coyote Flats,Texas
Yepper L3000 has power assist steering which is nothing similar to hydrostatic steering
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
I got my spinner yesterday. I'll install today. I rarely leave my tractor out at night. I have a three sided carport thing I built under my tall side deck on the house. Steel roofing , clear roofing sides, but if I leave my tractor outside I flip up the seat. I think the seat will hit the spinner and it won't flip onto the steering wheel. But I'll know today.
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
The spokes on my steering wheel are to thick to mount the Kubota spinner. It would just barely mount on the wheel itself. But I got the screws to start by two threads on each nut then tightened it down. I mounted it at the 7or 8 oclock position. The seat will flip by it onto the wheel.
I did get new blades for my land pride rotary cutter a month ago. I still haven't got to change thoses. But will soon.
Herkypilot
KX040, M7060HDC 12 & L3540
Oct 10, 2011
47
Carroll County, VA
For those looking to purchase the Kubota "deluxe" version, I just noticed yesterday that TSC has the exact same spinner w/o the Kubota name on the face for about $5 cheaper than anywhere else I looked.
HP
4,740
Never had one on the tractor BUT I did have one on my 57 Fairlane
Sharryn
'15 B3350, LA534A Loader, Land Pride RTA1258 Tiller, BH77 Backhoe, Forks
Aug 31, 2015
88
Alexandria, PA USA
I've found that backing up is much easier with the spinner - especially when connecting implements. Without using it sometimes have to reposition a few times before lining up correctly. With the spinner I can be more exact.
Couldn't agree more. And as someone else said, if you have a lot of backing up and moving forward a lot. I love mine and can't imagine being without it. I don't use it exclusively, but as mentioned above, it makes those instances much easier to operate.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,051
2,570
Near Lancaster, PA, USA
Orange rubbery-covered knob on the Kubota with power steering, aluminum on the Ford without power steering. Never had any issues with the Kubota but I have been whacked a few times with the knob on the Ford in the 25 years I've had it. I've used a few tractors without knobs and was glad to get off them.
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Ordered a seat cover and a spinner on Thursday should be here Tuesday. Looking forward to trying it.
Dr Honda
BX1870
Mar 30, 2015
174
Pitt, PA
mine had a spinner on it when it was delivered. I use it more than I expected. It's nice when using the FEL. One hand on the spinner an the other on the FEL control stick.
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
Will have to tell the dealer it needs to be on the 23s or no deal. Can see where it would be nice.
