I took the FEL off for the first time 3 days ago to install the MMM.
Today I tried to reattach the FEL and found one hose will not reconnect.
I did rotate the control stick as instructed before disconnecting the four hydraulic lines. I may not have done it correctly but I had no trouble disconnecting them and thought I had properly released any line pressure.
On reconnecting, three went on easily but the fourth won't snap in. The outlet on the tractor side has no pressure as best I can tell, however the hose on the FEL side seems to have pressure in the line. I can't depress the button inside the top of the connector. On the other hoses, the button will depress. I suspect this is why I can't get that final hose to reconnect.
What is the fix? Is there a way for me to release that pressure?
Thanks for any help,
Roll
Roll
