kupitz
BX2660 with LA243 FEL and Front mount BX2750 snowblower/2763A heated Curtis cab.
Just discovered a leaking steering cylinder hose and replaced, now I am leaking engine oil after putting everything back together. Seems my hose rubbed a hole through the pan. I did some searching and found this seems to be a common problem, only 97 hours on mine so this had to be routed wrong from factory!
So I was looking at the WSM and it shows pulling the motor to be fairly straightforward and simple after taking the hood off. I looked it over and it doesn't seem as easy as the WSM makes it out to be.
Anyone else done this on their BX and if so can you shed some light on what the WSM doesn't cover? Anybody had the dealer repair and if so how much?
Thanks in advance.
Thanks in advance.
