First "Mods" ......All in fun!
BotaTrac
Kubota B25D, Kubota L305DT, Kubota L2501D, Ford 681 Select-O-Speed
Mar 16, 2017
102
Hogwarts Academy
Stayed up late last night and watched hundreds of mods. Some pretty cool, some not so cool but a lot of ideas started swilling around inside my noggin.
Work lights are a must have. So they're coming sooner rather than later....
Practicality won out in the end - I made my first mod and bolted on a spinner! I decided that it's not a diesel tractor without a spinner! I also thought it would be prudent to make a "High-Tech" ROPS reminder so that I don't unintentionally make a taller doorway in the barn! :eek: - when the machine is in operation, I can just toss it over the FEL joystick.
gulfmp
BX2370, FEL, 54" mmm, BX 5450, Box blade
Dec 23, 2016
25
Central MA
I like the notes...
If I don't have it written down in front of me it doesn't happen!
BotaTrac
Mar 16, 2017
102
Hogwarts Academy
Weekend Mods- The book
Hello all:
This is the first in a 3 part post on some simple mods I did to my machine yesterday. I really enjoy locking myself in my barn, turning up the tunes and just slipping off into my own little world with a pellet stove and a case of Coors Light during the winter months.
Any upgrade I do, needs to be functional/practical - durable and look pretty professional.
The first job was to mount a clevis hanger from Ken's Bolt-on (http://www.boltonhooks.com/) to my loader bucket. Nothing crazy - I'm not a big fan of HEAVY pulling from the hydraulics - I prefer the frame, but an all purpose ring could come in handy.
BotaTrac
Mar 16, 2017
102
Hogwarts Academy
Weekend Mods 2
The second job this weekend was to upgrade the headlights. The stock headlight bulbs are 35W and spend most of their time behind the loader. Because they're halogen - they give off more of a yellow color light. I changed them out for a pair of 50W LED bulbs that give off more of a white colored light and are noticeably brighter. Super-easy to install, just plug and play. If you like them, I got them from here: http://amzn.to/2mhmyQM
BotaTrac
Mar 16, 2017
102
Hogwarts Academy
Weekend Mod 3a
This last one took a bit of planning. I got these utility hooks from eBay for $20. After running them through a wire-wheel to remove the chrome plating, I hit them with some etching primer and 10 coats of Satin Black Rustoleum. These would be perfect for mounting a hatchet to one side of my tractor and an ax to the other. I attached them with some grade 8 (5/8" X 2") bolts and Plasti-Dipped the pinch arms of the bracket.
BotaTrac
Mar 16, 2017
102
Hogwarts Academy
Weekend Mod 3b
The ax handle was 4" too long to fit on the side of the floor board without interfering with the tires/wheels so I cut 4-1/4" off with the miter saw to give it a nice, angled cut and then used Plasti-Dip to create a handle. I dipped the ax handle 9 times to get the desired thickness and had to cut the bottom out of one of the cans of dip, then couple them together to fit the entire length of the new handle including displacement.
Mr D
Mowing
Feb 9, 2017
31
Columbia City, IN.
Re: Weekend Mods 1
That's exactly the 1st mod configuration that I'm planning on my new B 2650
Yooper
3901 LA525
May 31, 2015
1,557
641
NE Wisconsin
Re: Weekend Mods 1
Hello all:
Some where in the human family tree, we are related. Right down to the same beer!
BotaTrac
Mar 16, 2017
102
Hogwarts Academy
Re: Weekend Mods 1
Well, obviously you are a man of great wisdom, class and culturre...
(bah, ha, ha, ha,ha,.....:D)
OC455
BX2350 LED ROP, FEL, Belly mower,modified snow blower, pole boom, middle plow
Sep 30, 2016
161
12
Rome NY USA
Re: Weekend Mods 2
I put a set of 10w LED bulbs in my head lights. One of the front "reflectors" of whatever you call them, came off and is rattling around in the headlight, and there's a bit of condensation in there now. Might have to replace those with a better set of LED bulbs.
At least seal better....
OC455
Sep 30, 2016
161
12
Rome NY USA
Re: Weekend Mod 3b
I like this idea...:)
BotaTrac
Mar 16, 2017
102
Hogwarts Academy
Re: Weekend Mods 2
I hope not. So far, so good!. One of the things I try to do before I buy anything from Amazon is to look a the reviews verified purchasers have left. Silly as it seem - I never buy the cheapest option as a matter of policy. it can be $2 more but never the cheapest option. Also, I replaced 35W with a set of 50W bulbs. If they fail or shake apart - I will certainly advise the community. Thanks for your comment!!
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
Re: Weekend Mod 3a
Do you have a link for these?
Sent from my SM-N920V using Tapatalk
3,520
Coors light ...........:eek: Thats right up there with Old Milwaukee
BotaTrac
Mar 16, 2017
102
Hogwarts Academy
Re: Weekend Mod 3a
I got 5 used ones from eBay for $20 delivered. They are called:
South Park Axe Handle Brackets - Side Mount
Here's a link: http://bit.ly/2nOd3ZE but they ain't cheap when they're new :eek:
Good Luck andtThanks for the comment!
