kubota l1500 reverse gear replacement
jkk04
kubota l1500, JD 410 backhoe,MF 30 tractor, IH TD14 142, BCS 715 tiller
Jan 9, 2017
79
PLYMOUTH CA
Hello,
I am newbie at this wonderful site for gary market kubota little tractors.
I have read so much information for l1500 that obtained recently.
It is very good condition except reverse function and steering assembly that needs to be replaced.
As you see the pictures, the reverse gear is bad and main gear as well but not as reverse gear.
any members can tell me how to bent reverse shift fork or ??? for more enguage to the main gear after replace the gear?
Thanks
Jkk
billrigsby
Mar 17, 2015
1,023
208
Florissant CO USA 8213'
www.facebook.com
Those pictures look like they could have been taken of the gears that came out of my tractor.
I have never heard of bending shift forks to get better engagement, I guess it's possible. Just replace all the gears and put it back together and be careful when you shift it and they should last quite a while.
Looking forward to watching your progress.
jkk04
Jan 9, 2017
79
PLYMOUTH CA
Hi, Bill. Thank you for replying.
Other confusion that it bring up is when I removed top cover, no interlock balls on the rails. But the l175 service manual described (according this site say it is same as l1500)
Do you know originally the l1500 model has inter lock balls?
Thank you
ps. I apologize that I have some language barrier
jkk04
Jan 9, 2017
79
PLYMOUTH CA
It is another frustration.:confused::confused:
Probably lost them long time ago.
Is it necessary to be on the rails?
And do you have any picture for locating the balls?
Also, do you have any easy way the forks back on the gears then set top plate on?
It is small world. Somerset is about 10 miles from where I live.
Thank you
6,993
Thank you
Is this a picture of your transmission?
If it is, the balls will be under the 3 springs on the top.
and transmission in neutral and shifter in neutral will let everything line up.
jkk04
Jan 9, 2017
79
PLYMOUTH CA
Thank you for reply.
Yes, it is.
I thought the balls are on outside rails.
will update with pictures once reverse gear installed.
Thank you again.
John
stavrossavvacoltd
Cyprus
Hello,
Thanks
Jkk
Hi Jkk,
I am sure you will find our website useful as we have a lot of spare parts for the specific tractor model! For more information please do not hesitate to contact us. Hopefully you will be able to repair your tractor soon! :)
Kind Regards,
Stavros
jkk04
Jan 9, 2017
79
PLYMOUTH CA
Finally, received the reverse gear.
But it is 9/16" longer than existing.
Any members in here can verify it is ok to install it?
Thank you
jkk
billrigsby
Mar 17, 2015
1,023
208
www.facebook.com
Well that is odd, I can't tell you if it will work or not. Where did you get that from?
I'm pretty sure the transmission is identical to a L 175 here in the states
Bill Rigsby
Florissant CO
1972(?) KUBOTA L-1500-DT
Great Bend M10 48" Front End Loader
Bush Hog 48 (SQ48R-3) "Squealer Mower"
Atlas 48" Landscape Box
48" Harrow Rake
Rhino 60" Rear Blade
4 Seasons haul-all Dump Trailer
Leinbach L7200 Post Hole Auger (9")
Draw Bar with 2" Ball
28" Fork Lift Forks
Sent from my Samsung Galaxy S7 using Tapatalk
jkk04
Jan 9, 2017
79
PLYMOUTH CA
Well that is odd, I can't tell you if it will work or not. Where did you get that from?..
It is came from Canada through the ebay.
The gear description is
One New Aftermarket Replacement Kubota Reverse Gear for L Series Tractor models: L1500, L175.
28 Tooth Gear
OEM Part #'s 34150-23130, 34150-23133, 34159-23100
jkk04
Jan 9, 2017
79
PLYMOUTH CA
It took some digging around in the snow, in the scrap metal pile but this is the one I took out of my L 1500, and the one I put in was identical....
Thank you so much for pictures.
That gear size is same as my existing gear.
I like to know where you got it?
Thank you
billrigsby
Mar 17, 2015
1,023
208
www.facebook.com
I think you just got a mixed up part, I am sure they will make it right
Bill Rigsby
Florissant CO
48" Harrow Rake
28" Fork Lift Forks
6,993
Nope, most grey market tractors will have different transmission parts and PTO gear parts.
Sometimes only subtle differences, like in this case gear length.
jkk04,
If the only difference is the length, and you can't get the right one without spending a lot more $$, have that one cut down.
jkk04
Jan 9, 2017
79
PLYMOUTH CA
Fortunately, the seller recognized sent wrong gear and accept return it for refund.
I will order it through the site that you meant because it is OEM gear.
will update.
Thank you again Bill and wolfman.
jkk04
Jan 9, 2017
79
PLYMOUTH CA
I am so glad having so much rain this year in northern California where has been 5 years drought.
Hope no more to say drought.
little more progress in rainy day here beside reverse gear.
1} replaced pto seal, head lamp bulb, horn, touch up paint.
2) hour meter fixed(the tip was broken in the assembly so I welded to make some point and grinded to make tip like flat driver inserting to the end of camshaft slot. Works very good.
3) fabricated to extend the fuel filter bracket for adding shut off valve that fuel tank doesn't have. It was so inconvenient to take out fuel tank without spiling and replacing filter in future(the line between tank and filter bracket was too short to add valve so extended bracket about 2" )
will updating more
jkk
