Wood Grapple Build
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
Cobbled up some linkage for my original idea for rotating the grapple. Also machined a restrictor fitting to slow down the hydraulic cylinder. Drilled the hole to .040".
Want to do some sea trials with it this weekend to see what works and what doesn't.
11,213
Humm, can't say I'm digging this phase of the build. :eek:
Please tell me I'm wrong if I am.
Your going to use the roll function of the bucket to control the twist of the grapple? :confused:
Sorry, but I see way too many issues with it being attach and rotated is such a manner.
I would opt for a electrically controlled split of the third function (or just adding a 4th function) over a mechanical linkage attached to the cross beam of the loader.
3,580
Looks like it works great! I would have expected no less. Very enjoyable to see your stuff being built & satisfying to see it function so well. :)
7,349
Really neat!
The drive for the rotator isn't what I expected, but that's ingenious. (Honestly, not really sure what I expected, but that's your Rube Goldberg addition you were dreaming up, correct?):)
Looks like weight/length have no issue with your tests, and probably could handle larger/heavier stuff easily.
The attachment plates to the SSQA frame would look really cool with some painted orange and black flames and/or shark teeth on the grapple jaws, with eyes, like the WWII fighter planes! Make up a name for your custom grapple, and paint it on the plates with the flames!!
Thanks for sharing - really enjoying it!
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
Well, I figured I owed it to myself to at least give my original idea a try. Didn't take much to link it up. I like the idea of controlling all the functions of the grapple with one hand, and I can control the curl function with a nice touch. I like the way it felt during the sea trials so I might just keep going. I can always switch it over to the linear actuator without too much trouble.
OTT (and most every other forum) does not host videos, uploading and linked them as you did is the correct way!
Very cool!
Thanks Kenny! Its been so long since I posted a video I couldn't see the forest for the trees!
Thanks Foot! How is the new lathe coming along?
Really neat!
Thanks RCW! Yeah, that was the Rube Goldberg I mentioned earlier. I was pleased with the sea trials and how things were working. Plan to use it for logs not much bigger than in the video.
One thing I don't like is the lack of vision. Would like to move it all the way over to the left but keep the weight divided between the loader arms. Gonna' stare at it awhile and see if the light bulb comes on.
Was thinking of naming it "The skeets". (Just kidding skeets!;))
11,213
Seeing it in action made me more of a believer in it! ;)
Just the negative side of me, but what happens if inadvertently hit the roll out, and you roll the unit too far forward?
Will it damage anything?
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
As you see it right now, yes. The plan calls for some way of stopping the forward roll before it gets that far. Thinking two heavy duty chains from the torque tube to the ssqa frame. These would be attached right next to the loader arms so as not to bend the tube.
7,349
One thing I don't like is the lack of vision. Would like to move it all the way over to the left.
Watching your videos, was wondering how much you could see. If anybody can come up with a solution...you'll get it.
Flames, etc. are from my Harley days, I guess....Black goes with orange on Harleys. ;)
For names, how 'bout Skeeter (no offense skeets), JAWS, SKILLS, Goldberg, Fire Starter, Ingenuity, Lignin (defining structure of wood). Gosh, I could go on... :D:D
11,213
Excellent!
I just wouldn't want you to inadvertently have a mishap and cause some serious damage to the loader.
My thought's on it would be a stop on the linkage for the rotate and a weak shear pin on the loader cross tube to linkage joint, just in case something failed.
I know arm chair quarterbacking, I hope you don't take offence, I do think your builds are excellent! ;)
3,580
I'm loving it, thanks for asking. The minor problems with the cross slide are now history. (@zero cost:)) It now has a quick change toolpost with 9 tool holders, added a shelf for tool holders, replaced to tailstock spindle key to remove play, changed oil in gearboxes, some oiler buttons replaced. Also tracked a high speed vibration/noise to the outboard ends of the leadscrew & feed driveshaft: the steel shafts were spinning directly in a cast iron block, which was worn. Bored the block out for two 1" oilite bearings, then bored those to fit the shafts- smooth as silk now.
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
Excellent!
No offense at all! More eyes on my projects only make them better.
I used hose clamps to attach the linkage anchor to the cross tube, and as I looked at it, I thought this might be the way to go for the final assembly. If something got away from me, these would break. Kind of like a fusible link.
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
Very, very nice! I like the way you've got your tooling within arms reach.
Let me guess, your having fun?
Tooljunkie
May 13, 2014
4,150
35
I'm a little envious of your skills, and attention to detail. My south bend (1947 9x48) is a tiny thing, but serves me well. Not very clean,but i did get it out of the dust in my repair shop. Its a difficult thing keeping it clean and tools organized. End of day i run out of steam and give up. I leave my cleanup until morning when i feel a little refreshed. But it being in another building i forget it needs attention.
I like the concept of the grapple and it appears like it should lift a fair size log. Any guess what it will lift?
OldeEnglish
Jul 13, 2014
766
Western, MA
That's really slick! I've been following your build and was curious what the advantages of this compared to a regular grapple would be and I totally see it now. That would come in handy for building a stone wall!
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
My Dad had the same lathe you have, and about the same vintage. He sure had fun with it!
I hear you on the shop clean up. That's pretty much the way I operate too.
I'm going to try and not get too carried away with what I pick up with this. I built it with the thought of moving short length of logs around and if it can handle 200-300 lbs, I'll be satisfied with that. I'm also planning to experiment with moving it far to the left so I have better vision of what I'm picking up. Don't want to twist the loader.
Thanks OldeEnglish! I got pretty good with my brush grapple picking up lots of different things, but there were times when I wish I could rotate it to orient it to what I was picking up. That's where this guy comes in. I agree, this would save your back on a stone wall.
