That will only work if the stabilizers are inside of the lift arms, not outboard.I think you need to tighten up the slack adjusters between your drag arms of the 3pt hitch. It prevents the arms from spreading out.
I see those. Are they that good?consider getting the extra heavy lynch pins from Tractor Supply. They are black and quite a bit stronger than the gold ones. Not that much more expensive either.
http://www.tractorsupply.com/tsc/product/countyline-lynch-pin-7-16-in-heavy-duty-s070913tsc?cm_vc=-10005
The others are $0.25 a piece....
Ha,Ha! They are not 25 cents each when they break all the time and have to be replaced. Not to mention the aggravation and bother when the implement slips off.75 cents more, holy crap!
True, didn't know they were heavier duty. I broke a couple this spring with my box blade - I'll have to try some.Ha,Ha! They are not 25 cents each when they break all the time and have to be replaced. Not to mention the aggravation and bother when the implement slips off.
