L2250 with BF400G Hydraulic issue
precision
L2250
Oct 23, 2010
Monroeville, NJ, USA
I had to replace the 4 hydraulic hard lines on my BF400G loader and I'm having an issue with the loader. The bucket roll works fine, but I'm having 2 issues.
1. If I pull back too far on the lever to raise the bucket the bucket won't move. Pull back just a little and the bucket raises without any problem.
2. I can't lower the bucket unless I float it. If I run the tractor at higher rpms for a little bit and then try to lower the bucket it works, but as soon as I come back to idle I have the same issue again. What would cause this issue?
Thanks
Fender5803
L3901 LA525 BH77; LP 1860 rotory cutter; LP 1060 grapple; forks & bucket
Aug 9, 2015
37
Henniker, NH
Wish there was an answer here because I'm having very similar problems today .... :((
11,280
State your problem and exactly what has transpired, and we should be able to help.
You'll find that with a lot of the very old posts there wasn't answers as the forum membership was very small at that time.
Fender5803
Aug 9, 2015
37
Henniker, NH
Thanks Wolfman
I figured it out. I hadn't hooked up the loop I undid when removing the backhoe - oops (I didn't want to hook a blue fitting into a red one) That said I also learned to really move the loader lever to take ALL the pressure off - which made the quick disconnects way easier to remove :)
