i bought a attachment that had curved spring tines about 18-20 inches long. to scrape the ground and catch roots with. when the tines filled up i would raise it just enough to drag the roots and limbs to the side. but not high enough to let them fall. several passes from different directions took care of most of the roots. the next time i used the rototiller, i hardly had any junk get tangled up in the tines.
some equipment that might be interesting for you...
i couldn't find an example of what i'm using..
http://www.stevenstractor.com/farm-equipment/gardening-implements.html
Yep I'm not sure a landscape rake has enough backbone to pull the roots out, a good C tine cultivator with chisel points would probably do it or at least ball them up. Depending on how many rocks are left maybe a good discing to cut them up more and running the tiller a few more times would get more of them out...He's probably talking about a field cultivator.
Ripping it up really good with a subsoiler then following up with a chisel plow or field cultivator works really well for getting up the roots.
Or you could pull the bottom plow back out and turn it again perpendicular to your original pattern and then till it again.
I like pulling a bottom plow
I've been trying to smooth up and shape what my wife & I refer to as our yard. Too many rocks and sandy conditions but over the last few days its shaping up somewhat. I'm using a 5ft Tractor Supply rototiller and its been quite the beast. Very pleased with it to date. Not sure there is an ideal set of tools and implements for each situation. To some extent it seems you get by as best you can with what you have.
