Clearing land for a garden and orchard
BCrouse
197
PA
A day settling. The roots seem to be poking through more.
Options:
1) hit it with a landscaper rake and try and pull some of the roots out. Then depending on the surface, another pass with the tiller
2) hit it a few more times with the tiller, hoping to chop the roots up.
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
I wouldn't be able to resist taking a landscape rake to it. I am not certain stuff grows better, but it would make getting seed started easier if you are doing rows of veggies. And the fewer of those roots left around to start new weed plants the better. The time I rototilled in the corner of the mint patch I had mint come up everywhere, not just in the corner.
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
That looks like rich soil. But the roots you are dealing with are different than the larger ones I had. Mine varied from as thick as your arm to as thick as your leg. Once they dried out they stacked like lightweight driftwood and burned up completely. This viney clingy network you are dealing with may not cooperate with the landscape rake. I'd try anyway if only to comb out as many rocks as possible. You may find it more effective to let the ground fallow this season; see what growth pops up from those roots and use a weed killer on it. Once dead another tilling should break it loose and then it might rake out better. Just a thought.
Best of luck getting it like you want it.
Clay
BCrouse
197
PA
Another suggestion that was made was to clear as many rocks as possible then hit the roots with a bushhog. It hasnt rained since i tilled yet. I would think the bushhog's rear wheel would sink quite a bit. Would make setting the cutting height interesting.
And it would be one heck of a dust storm!
tempforce
B2650HSDC
Jun 23, 2012
389
bastrop, tx
i bought a attachment that had curved spring tines about 18-20 inches long. to scrape the ground and catch roots with. when the tines filled up i would raise it just enough to drag the roots and limbs to the side. but not high enough to let them fall. several passes from different directions took care of most of the roots. the next time i used the rototiller, i hardly had any junk get tangled up in the tines.
some equipment that might be interesting for you...
i couldn't find an example of what i'm using..
http://www.stevenstractor.com/farm-equipment/gardening-implements.html
BCrouse
197
PA
Is it this?
http://www.everythingattachments.com/Landscape-Rake-York-Rake-s/87.htm
scdeerslayer
MX5200DT
May 23, 2016
434
SC
He's probably talking about a field cultivator.
Ripping it up really good with a subsoiler then following up with a chisel plow or field cultivator works really well for getting up the roots.
zload
B2400HSD/47 John Deere Model M
Apr 14, 2015
91
FL
Yep I'm not sure a landscape rake has enough backbone to pull the roots out, a good C tine cultivator with chisel points would probably do it or at least ball them up. Depending on how many rocks are left:eek: maybe a good discing to cut them up more and running the tiller a few more times would get more of them out...
Or you could pull the bottom plow back out and turn it again perpendicular to your original pattern and then till it again.
I like pulling a bottom plow:D
BCrouse
197
PA
I have a new (old) piece of farm kit I am fixing up. Its a homemade toolbar with a mix of parts what I believe are JD and IH.
Ordered some new/replacement parts to swap all of the shank attachment on it between sweeps and chisel points. So, I should be able to pull that through with the points once I get everything replaced.
clay45
Feb 6, 2015
279
SC
I've been trying to smooth up and shape what my wife & I refer to as our yard. Too many rocks and sandy conditions but over the last few days its shaping up somewhat. I'm using a 5ft Tractor Supply rototiller and its been quite the beast. Very pleased with it to date. Not sure there is an ideal set of tools and implements for each situation. To some extent it seems you get by as best you can with what you have.
BCrouse
197
PA
Lookin good. Im getting there.
BCrouse
197
PA
My single row planter arrived. I got it assembled and tested the seed plate for peas with the cover crop seed I got. Oats and peas. Worked well.
I still need to take the landscaper rake to it I think. Those roots are just overwhelming.
Looking towards the garden. Its still behind some brush from where I am. Orchard will be straight ahead and a pond (maybe...) off to the left.
BCrouse
197
PA
Had a little time this AM before I had to do some other things...
Set the rake at an angle.
After 2 passes (mostly, only 1 pass on the left side)
Slowly pulling the roots and larger rocks out.
Im going to take all the leftover root and dirt and put it into the compost pile. I don't want to waste good organic material and dirt. It'll get incorporated back in at some point.
BCrouse
197
PA
I think I'm finally ready to plant.
I stepped off a section for the garlic. The rest will get oats&field peas planted as cover crop.
clay45
Feb 6, 2015
279
SC
Good looking soil; hope it yields a fine crop. Nicely done.
BCrouse
197
PA
I got a bunch of rows of oats&field peas planted in the main field.
Front section in the bottom right here is stepped off for garlic and spinach.
I still haven't done anything with the side field. I might try rye in that one.
