NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
I was doing the first 50 hour service on the tractor. Swapped the oil and filter, no problem.
Next up is to change the transmission oil filter [HST] and the hydraulic oil filter.
Although the manual says not to swap the fluid till 400 hours, it seems cleaner to drain the fluid and then change the filters. I had done this before on a B3350 and noticed some shavings when I drained it, so I get the satisfaction of knowing I've got the cleanest fluid possible.
I removed bolt #1 and drained the transmission fluid from that spot. When I put the bolt back in I hand screwed it in and then used my wrench to tighten it and then it just went loose, kept spinning, and not tightening anymore.
I loosened it and took it off and when I did a part of the thread fell off the top of the bolt. (see pictures)
When I looked closely, I also noticed that there was this grey matter wedged in the thread of the bolt.
It's hard to see but I tried to get a clear shot of the drain hole. I'm not quite sure what to do. I tried to thread it back in by hand but now I'm meeting resistance. I don't want to force it back in and make it worse, and not sure if just a new bolt will fix my problem or if the drain hole thread is defective or needs to be cleaned? Please don't tell me it has to be re-threaded.
Also, should I be replacing the washers on the bolts, It appears there's a rubber ring on the inside of the washer . I replaced the copper washers on the oil bolts.
I didn't remove and drain bolts #2, or swap the filters yet, it's getting late.
I've swapped fluids hundreds of times. This has never happened to me before.
Any advice would be appreciated.
