i have a new rear cement mixer for my L3400 --It has 1 piston for the dumping so i need a hook up for 1 hose for the ram--what is the easiest and least expensive way to do this--Part numbers would be very helpful !!!! Thanks
how would i do that--i would be fine with that !!Do you have a loader? If so you could use the bucket curl circuit. Just a though.
thanks---I only need 1 hose so I will give it a try--just need a extension on the hose to reach the front !!!!I think Sammy is saying that you could disconnect the bucket curl hoses at their quick disconnects (or add a quick disconnect fittings if not already there) and then make up a couple of hoses to run from those disconnects to your cement mixer dump cylinder. When cement mixer is no longer needed just move it and reconnect the hoses to their original locations. Sounds like a good idea.
Thanks Guys !!!!Sorry I was not clear but that is what I was trying to say.
