L3400 Rear hydraulics ???
Seneca SS
Dundee,N.Y.
i have a new rear cement mixer for my L3400 --It has 1 piston for the dumping so i need a hook up for 1 hose for the ram--what is the easiest and least expensive way to do this--Part numbers would be very helpful !!!! Thanks
Sammy3700
Feb 20, 2012
437
41
Red Springs, NC
Do you have a loader? If so you could use the bucket curl circuit. Just a though.
CountryBumkin
BX2370 w/LA243, Bucket, Grapple, QA Pallet Forks, 60" MMM, rear blade & rake
Sep 27, 2015
568
Central FL
I think Sammy is saying that you could disconnect the bucket curl hoses at their quick disconnects (or add a quick disconnect fittings if not already there) and then make up a couple of hoses to run from those disconnects to your cement mixer dump cylinder. When cement mixer is no longer needed just move it and reconnect the hoses to their original locations. Sounds like a good idea.
Seneca SS
Dundee,N.Y.
thanks---I only need 1 hose so I will give it a try--just need a extension on the hose to reach the front !!!!
Seneca SS
Dundee,N.Y.
Ok so i disconnected the bucket curl hose and connected the 1 hose from the mixer--it will pick the mixer bucket but dont seem to get it to release :confused::confused: here is a picture of the mixer--
MtnViewRanch
796
233
Lakeside Ca.
You need to use the lift circuit. The mixer is a single acting cylinder. Use the lift circuit to raise the mixer, put the lift circuit into float mode to lower the mixer. That or shut the tractor off and then move the joystick when ever you need to lower the mixer if you stay with the curl circuit.
Sammy3700
Feb 20, 2012
437
41
Red Springs, NC
After seeing the picture the mixer will gravity dump when the joystick is moved in the opposite direction. The hose is at the piston end of the cylinder meaning it will on pull the cylinder in under pressure. it has to have weight to dump. Try filling it with dirt and try it. We have a Woods 10' pull mower at work with the same style cylinder (hose on opposite end) it has pressure to raise it and gravity lowers it when you move the control. Hope I made sense of this for you.
