What did you do to your Implement today
billrigsby
Mar 17, 2015
1,064
278
Florissant CO USA 8213'
www.facebook.com
AND, Here you have it sports fans......
I ordered the new decals today and then it will be done.
I think the last implement I need (read "want") is a rear 3-point scoop.
Not sure I "need" it, but it may come in handy and would be a good ballast box.
(yep that is my reasoning). :rolleyes:
Next year though, first, is a pole barn of sorts, to store all this stuff out of the elements.
scottfarm
l4701
Nov 29, 2016
15
Sneads
I sandblasted my 20 year old Brown 460 bush hog and painted it. I drove up to Ozark Al bought the paint, decal kit, and chain guards for front and back. I have worked the crap out of it. It is absolutely the toughest piece of equipment I have ever owned and now it is good for another 20 years. That 250 lb stump jumper stops at nothing.
billrigsby
Mar 17, 2015
1,064
278
www.facebook.com
Picked up a 3-Point Dirt Scoop over the weekend,
Has been on Craigs-List over a month,
owner was asking $225, got it for $165, :)
Made by a company called Southeast Mfg Co.
They were apparently out of Neodesha Kansas,
but I can not find any other information about them, :mad:,
Always nice to know a little history of who made my stuff.
It is the RIGHT color, but still needs some repainting :D
7,712
billrigsby
Mar 17, 2015
1,064
278
www.facebook.com
Picked up decals today for the Leinbach Post Hole Auger
and the Southeast 3-Point Dirt Scoop
Hope to get the decals on the auger this weekend,
and already have the scoop dismantled for re-furbishing.
Will also get going on that this weekend.
billrigsby
Mar 17, 2015
1,064
278
www.facebook.com
Another one for the books......
Got the auger done......
Just missing a decal for the driveshaft
(coming from a gal at Bush Hog)
since they are all the same.
May start a on stand
before the dirt scoop, otherwise I have to
"Look for a tree to rest my post hole digger up against" :D
Going to steal SkylineAcres16 design http://www.orangetractortalks.com/forums/showthread.php?t=28369
with a few mods, design is in process. :D
billrigsby
Mar 17, 2015
1,064
278
www.facebook.com
with a few mods, design is in process.[/SIZE]
This is where I am at so far, going to add a support for the tractor end of the boom
and using two 24x24 pallets connected together for a smaller footprint.
I think my forks will still pick it up (only 28"), and still not attached to the bucket,
may need to devise some extensions when I get around to them?
billrigsby
Mar 17, 2015
1,064
278
www.facebook.com
This is "next year". As soon as the ground thaws.......
Okay technicality, you remind me of my significant other.
As usual I stand corrected.
Bill Rigsby
Florissant CO
1972(?) KUBOTA L-1500-DT
Great Bend M10 48" Front End Loader
Bush Hog 48 (SQ48R-3) "Squealer Mower"
Atlas 48" Landscape Box
48" Harrow Rake
Rhino 60" Rear Blade
4 Seasons haul-all Dump Trailer
Leinbach L7200 Post Hole Auger (9")
Draw Bar with 2" Ball
28" Fork Lift Forks
Sent from my Samsung Galaxy S7 using Tapatalk
11,243
Bill,
I think you have more money in your labeling that I do in all my equipment! ;)
billrigsby
Mar 17, 2015
1,064
278
www.facebook.com
Bill,
LOL
Actually the printing is pretty cheap when you do the artwork yourself on the computer,
(graphic / sign designer in a previous life)
Also Bush Hog and Rhino were very helpful and provided most of that stuff at no charge. :rolleyes:
But it all looks pretty until I start using it. :D
asgard
B2301, 60 inch deck, 51inch blower
Oct 22, 2016
147
15
Ontario, Canada
Can I ask if you are construction this tractor shed with steel. Reason I ask is you have an open clear span of 216 inches and a section of 5.75 inches.
billrigsby
Mar 17, 2015
1,064
278
www.facebook.com
No it is all wood construction.
Identical to my wood shed at a previous home, except deeper.
The 5.75" you see is a dual 2x6 header, 18' in length.
This is a work in progress, and I may not go a total of 36' in length.
Bill Rigsby
Florissant CO
48" Harrow Rake
28" Fork Lift Forks
Missouribound
Jun 17, 2014
668
62
Missouri
That's not enough for that span. Steel would be a better choice. It will sag before you know it. If you plan to have that inspected it's unlikely it would pass. Sorry.
billrigsby
Mar 17, 2015
1,064
278
www.facebook.com
Well, the wood shed, built in 98, was still in perfect shape last year when my X sold the house.Thats 18 years, and it is a single header, I am beefing this up due to what is in it, and it will probably be shorter. Add to that less snow load here, I think I will be Okay.
We do not permit or inspect out buildings unless they are for human use, shop garage etc.
Bill Rigsby
Florissant CO
48" Harrow Rake
28" Fork Lift Forks
