L3400 front end loader Hydraulic issues
Christopherjmccaw
Still chain saw
Apr 19, 2016
9
wheeler
L3400 having trouble with the front end loader. It will only lift when the stick is pulled about half way back if pulled all the way back it doesn't move at all. When lowering bucket it will only lower in float position all the way forward. Bucket tilt works ok.I can not apply any down pressure with the bucket. Any ideas ? Fluid level is good, tractor also has a back hoe attached the back hoe seems slow but has good down pressure.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
10
East Hampton, CT
Problem description sounds like one of two directions.
A. Valve body issue, swapped hoses, quick connect clogged/partially clipped on, etc.
B. Hydraulic issue dead headed relating to backhoe or 3 point lift arms.
Make sure your 3 point lift lever isn't in the "full up" position.
When were your filters and fluids last changed? Longer interval could mean particles or issues caused by dirty fluid.
Christopherjmccaw
Still chain saw
Apr 19, 2016
9
wheeler
Hydraulic fluid and filter are changed once a year since I have owned it.I will change it this weekend and check the other things that you mentioned. Thanks.
CaveCreekRay
Jul 11, 2014
2,631
103
Cave Creek, AZ
You might have a sticky valve in the control module...
6,902
Sounds like you have hoses swapped.
Most likely the 2 lift hoses. ;)
CaveCreekRay
Jul 11, 2014
2,631
103
Cave Creek, AZ
Has the FEL been removed and replaced recently?
