Parts Unavailable (dilemma)
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
It would appear that a couple of key parts for my project are "discontinued"
from Kubota, the most important is the battery support or tray, mine is shot....
I was given a price of $106.20 from the dealer, and about to hold my nose and order it,
then I got the news it was NLA.
I was using the part number for a L175, also discontinued is the same part for
the L225 and L185. Are any other models the same or similar? The dimensions are....
Also I was given a price of $223.05 for the bumper,
that ain't happening, even if it is still available.
Can anyone please take some good pictures and measurements
of a L175 (or compatible) bumper so I can fabricate one?
Neither of these have been found in any salvage yard either.
If anyone can help I would be forever grateful ;)
(That includes a source for GOOD old parts !!)
3,049
Can that support tray be fabbed up? Or you trying hard to have original stuff?
9,117
You have a couple options. Have a new plate welded into the one you have.
Or making a new one yourself or having a welding shop make one.
Check an auto parts store as well. They sell battery trays and boxes. They might have one you can cut and weld into the existing brackets.
Or there's always a tractor salvage yard. Or find someone that's parting one out.
olthumpa
L275
May 25, 2011
1,505
Maine
I had the same problem, battery tray all rotted out. I took some 1" angle iron and a piece of sheet metal and welded one up - not very complicated. Good luck in whatever you choose.:)
3,049
thats what I was thinking, by the TIME that rusts out.......you wont need the tractor any more!;):)
7,573
Bill, you may have to do like they do in Cuba. Fabricate it so close to original you can't tell the difference. Then don't tell anyone you did it, and they won't know!
3,015
The battery tray is also part of the hood support system on my L185 so may be on yours also. Keep the legs and build the rest up. I can provide pictures since I bought a new one a while ago. I can also provide dims for the bumper. It may be a week or so though.
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Yes it is also on mine,
Thanks for coming to the rescue again with the bumper dimensions :)
Still can not wrap my head around that Radiator Decal at $25+
Does not look to be gold inlayed! :mad:
9,117
I was gonna ask you for the sticker numbers :D Not looking for the safety decals, more for the operating ones :D
3,015
Bill I don't recall the price that high but may have blocked that out, I tend to be a little compulsive to complete a task and once you start ordering a hundred dollars of stickers what's another $25 .....
Darren I can send you an excel spreadsheet and scans of the stickers if you PM me you email.
9,117
Thanks, Bill forwarded them through Dropbox ;) It has the one sticker I was missing in the l185 parts list :D:D
3,015
here are some pictures of the bumper (hope the tape measure can be seen/read).
The bar with holes in it is actually bent like an angle iron with the vertical leg that you can't see being about .5 inch tall
3,015
More pictures of bumper:
This hook is a bent (curved) rod that is about .5 to .75 inch diameter.
Plate that bolts bumper to tractor (sorry it is upside down)
3,015
More bumper pictures:
This picture below is upside down. These plates are welded to the bumper on each side of the tractor. No idea what they are for. They are about 1/8 inch thick.
The picture below is the backplate that is about 3/8 to .5 thick. It is bent at both ends and then the bumper bar is welded to it.
Thickness of bumper is about 3/16
3,015
This is the back plate or the bumper.
This shows a stiffener bar welded next to the hook.
The four weights for the bumper. I recall they are 55 pounds each
3,015
Now for the battery tray:
Length across the width of the battery (front wheel to front wheel)
The length along the battery tray front to back
Location of the tie down points for battery retainer.
3,015
More Battery tray pictures:
This is the support that is on the right side of the tractor (for the air filter)
depth of the tray is about 1/2.
I think it would be better to have some drainage in the bottom or the sides.
Let me know if you need any other pictures.
