L1500 Installed Clutch - Issues?
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
I installed the clutch today and put the Trans back on, when I was mounting the
foot pads I ran into an issue, the pedal hits a protrusion on the bottom of the pad.
I looked into the clutch area through the inspection window and not sure I like what I am seeing?
This is a photo from rbrown7713's post on clutch of the pressure plate
This is what the "fingers" on mine (installed) look like
This is clutch lever position before dis-assembly
and after re-assembly
Input shaft seems to be ok
Any insight before I tear her down again?
10,838
Your going to have to be a little more specific as to what your calling the protrusion
So be very specific on what is hitting where.;)
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
It is a support gusset, about 1 inch by 1 half inch, If you look at the PP finger photo, it looks like they are not seated properly, not sure what would cause that. That is causing the throwout bearing to be in a different position also causing the pedal to be in a different position than when it was disassembled. Therefore it hits that support gusset.
But I think the pressure plate is the problem.
Bill Rigsby
Florissant CO
1972(?) KUBOTA L-1500-DT
Great Bend M10 48" Front End Loader
Brush Hog 48" "Squealer Mower"
Atlas 48" Landscape Box
Rhino 48" Rear Blade
Draw Bar with 2" Ball
36" Sears Snow Blower (still to be mounted to the front PTO)
