Rebuild Kubota L275 Steering Box
ironpony
B7100
Mar 4, 2016
84
Lancaster Ohio
Ummm.........I would clean that area a lot better before removing the steering shaft and having that stuff fall inside. looking at the pic I would say the locknut is for the column itself.
9,912
The L275 has a lock nut (see picture) instead of the 4 bolt design. How do you get that lock nut off?
Make sure the keeper tabs are bent down then use a big wrench.
I will second cleaning off the area before you remove the steering box, as you'll just dump all that trash onto the clutch.
Read the WSM as it tells you what the purpose of that lock nut is. ;)
kubotasam
Apr 26, 2010
1,211
135
Alfred Maine
When you remove the pitman arm use a jaw puller not a pickle fork. A pickle fork can break the end of the sector shaft.
