Posting multiple photos HELP!!!!!!!!
bcbull378
Sep 6, 2011
579
32
Ventura Ca
How do you post multiple attachments? I can get one one here but the second attachment deletes the first attachment. HELP !!!!!!! my 6 year old granddaughter isn't here to help Papa
mdhughes
L3901DT
Dec 10, 2014
1,273
817
Ste Geneveive county, MO
Click on the "Manage Attachment" button:
Then another window "Manage Attachments" with pop up:
The click the Browse button, select the first file. The click the Upload button. When that file is uploaded, repeat the steps till you have all the files you want to upload.
5,898
Go down to "Manage Attachments"
Click on "browse",
Select file from Hard Drive (or where ever you have it),
Click "Upload" (in upper right hand corner),
For Picture #2.....go back and click "browse" again (and repeat as above),
When all pictures are loaded click "Close this window",
Send so we can all see it!!!
sheepfarmer
Nov 14, 2014
4,451
679
MidMichigan
Make sure the dimensions of the picture are as seen in the manage attachments table too!
And the only other snag I've hit is maybe the file name. It seems that the forum software is pickier than your computer may be.
bcbull378
Sep 6, 2011
579
32
Ventura Ca
When I try to post multiple photos it doesn't say Browse it says choose file , after I upload first photo I load second photo and it automatically deletes the first photo I'm not sure what else to try.
bcbull378
Sep 6, 2011
579
32
Ventura Ca
I've done everything you guys have suggested , it doesn't say browse it says choose file with are in my photo library ( I-Pad ) and when I try to upload the second attachment it deletes my first attachment . Very frustrating what to do next.
5,898
Mdhughes, I can barely go thru the process in my head and tell someone how to do it, and you post all those examples!
I need to get someone to help me with that kind of stuff.
I can't turn the TV volume up with one remote because there's a sound bar attached and it takes a different remote, and I can't figure out how to/or is it possible? I feel bcbull378's pain.
coachgeo
Nov 16, 2012
2,460
36
Southern OH
Choose ONE at a time. You can't choose more than one at that step. You choose a single file for uploading. once it completes that pic's upload; the manage files returns and you repeat the process for next pic. Don't close the manager till you've uploaded all the pics you want in the post. Think 5 that is the max per post. Keep eye on top of manager. It will add some text to it to identify if the pic was too large or of wrong file type etc.
did test to make sure there were no errors on the board by loading two irrelevant pics. They are below
Kennyd4110
Vendor Member
Sep 7, 2013
1,261
490
Westminster, MD
www.boltonhooks.com
I've had the same issues posting from my iPad at OTT, I don't think there is a solution that won't involve the admins and a software upgrade. Works fine on other forums so I know it's not on my end.
mdhughes
L3901DT
Dec 10, 2014
1,273
817
bcbull378, Other than it saying choose file instead of Browse, does the "Manage Attachment" window look the same? After uploading the first file, does it show up in the area that I have marked with the red square? What type of computer/hand held device are you using?
6,929
With an i-pad, it might be easier to upload files using the tap talk app. When writing the post, you hit the photo icon above the keypad as your writing the post. It will bring you to your files, and then you can tap on the photo you want. It also makes it hand since you can place the photo directly in the middle of the post as your writing it :D
bcbull378
Sep 6, 2011
579
32
Ventura Ca
Yes I have no problem loading the first photo it's when I upload the second photo the first is deleted, manage attachment looks exactly the same it shows up just as you outlines thank for trying to help guys I must be an idiot. We have the grandkids Monday I'll see if my 6 year old can figure this out. Im pulling the photos from my photo library Before OTT changed the format ( server I think that's what it's called ) I didn't have these problems
coachgeo
Nov 16, 2012
2,460
36
Southern OH
[browse] vs [choose]
prior to doing anything with photos; if you hit the [paper clip] button amongst the text menu items in the Reply to Thread panel this will take you to the Photo Manager pop up. There the button you use to get pics from your hard drive says CHOOSE.
If you go into the Photo manager via section below the Reply to Thread panel, labeled additional options ...... one will come up with the same Photo Manager pop up but it will say BROWSE.
They function the same way.
