In order to change the fan belt, you'll need to split the FEL pump driveshaft at the double row chain coupler- not a big deal, but a pain to access without removing more stuff.
The steering gear box is filled with 80-90W gear oil, check for water when you drain, a common problem if it was stored outside. (hard on the lower bearing, which fails, taking out the rest of the parts)
The drain & fill plugs are #30 & #22 respectively, if I remember right.
(my B7100 is 150 miles from me right now)
