'83 B6200. Was running 2 weeks prior. Turn key to heat plug..it heats up, turn key....nothing. Put a battery charger on the battery for 2 days, doesn't help. Tried to jump tractor off...doesn't help.
Any other things to try?
Are there any fuses/etc that I can check?
How much of the wiring is necessary for the 6200 to run?
There is a fuse holder (blue w/ red stripe if I remember correctly) that has gotten broken (does this one go to the horn?)
Any suggestions that can be made would be appreciated! If you have a suggestion...please send message to
keith (at sign) keithswebdesign.com
Thanks
Keith
Thanks
Keith
