my Kubota L3200 hydrostat is normal when pedal is pressed slowly but once towards full speed it dies off and goes slow, from a stop is pressed hard all the way down it dies off and crawls right away, tips on whats going on or how to check pressure would be great, put new fluid and filter on both Kubota filter and fluid, thanks
Looking and reading what the others have said, I am trying to understand if this is a tractor problem or user problem.
If you are in high gear and flat ground, then a little "pedal" it should move forward and as you increase speed and increase pedal you get to rolling good fashion - if in high gear and stomp the pedal - it is gonna moan like little b!tch.
On my BX - on an incline, high gear, lets say 20° incline, she is useless.....many have said that pressing on the pedal easy will get up the incline....horse hockey, when the BX25 FEL / BH has 7oolbs on the ass-end and 4oolbs on the front, there aint no way it can manage the hill. I have tried too many ways too many times. Now - even with a full bucket - flat ground, a little pedal and it will go lickety split. Now in low gear she will pull till the point where all tires are spinning.
now - are you in high gear and stomping it?
Or on flat ground and getting up to speed and thennnn something happening?
If you are moving then giving it more and it dies, there is something wrong.....
Explain further as to what happens and when it is happening.
