Folks.... I'm picking up a second hand 3010 w/LA482 loader. The loader joystick seams to be sticky and does not opperate as designed. Example.. At times the bucket will raise normally until 3/4 the way up then slow tremendiously. A couple on/offs with the joystick and it may proceed up. Same in the down position... It "appears" to work ok side to side (dumping bucket).
I also notice the front bucket will not lift the front tractor wheels off the ground.
The present owner said his mechanic (don't think he was professional mechanic) said this was a sticky piston within the single control joystick.
Thoughts? Does this sound fairly inexpensive to repair?
BTW.. This unit has a 4690a Backhoe mounted...
