B7100 steering
gm86toygs
US
1996 B7100 I have a good bit of play where the front axle bolts to tractor should this be tight or have some play there
Sent from my SCH-R530U using Tapatalk
2,561
you mean in the tie rods? If so - mine are the exact same way!:)
5,606
If you're referring to where the front axle pivots under the engine, you can adjust that.
Remove the hairpin and tighten the nut. Some put a flat washer behind the nut to get it even tighter. Needs some slack, but not wobble. Remember to reinstall the hairpin.
If you have too much slack to adjust out the only way to get to the pin to replace is engine removal.
2,561
D2Cat,
I'm gonna go look at mine due to what you said ....mmmmmmmmmmmm:)
2,561
It'll take you longer to find the wrench then to make the adjustment!:D
dayum I know that's true !:) - off the top of your head ? what size is it ?
BACnOrange
B7100HST 4WD
Apr 2, 2015
G'vegas, SC. US of A
I just noticed mine doing this yesterday. When turning "the play" in the steering wheel, the front axle pops and wobbles between the two mounts. I'll try the above remedy soon! Thanks
