Work Shop Manuals (WSM)
breenfarmer77
Kubota L35 tractor
Jun 26, 2016
Durango, Colorado
I visited the servicemanualvault site and found L3540 and L355 but no L35 model. Photo images of the other two don't look like my L35. Thought this L35 was a particularly common Kubota. Any sense if they are similar enough to be able to use the manual to repair a 4x4 front axle issue?
Rolling Stock
L4350DT, LA950 loader
Jun 17, 2016
25
Othello, WA
Hello all,
New maintainer of a used L4350DT with a LA950 FEL. I cannot find a manual for the LA950, I only see it for the LA950A. Are there many differences between the two? I specifically need information on how to remove the FEL. I know there are 4 bars to be used, I have the 2 mounted across the drivers station and am missing the 2 that get mounted to the lower rear frame rail. After I receive these 2 lower bars how do I attach them to remover the FEL? A picture would suffice, a manual would be preferred, any help is appreciated.
I received my manual for the L4350 and found a section in the manual for the FEL. Here are a couple pics with it removed.
Josef
2014 Kubota MX 5200 with 6 la1065 loader, sq172 Bush hog shredder, 6 ' Armstrong
Feb 25, 2016
282
victoria tx 77904
Looking for Work shop manual for mx5200hst. Thanks in advance
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
How close is a MX5000, there's one on the net if you do a search, not sure if it's HST
11,016
Your going to have to go new printed for that model.
If you need the P/N for it just ask.
Not close at all! It would be pretty much worthless. ;)
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
kubotabooks.com now has a copy of the B7100HST WSM. With bookmarks.
Hazadad
Zen Noh LF1500
Aug 15, 2016
Brisbane, Queensland, Australia
Hi,
I have a ZenNoh LF1500DT which is the Jap farmers version of the Kubota L1500DT, i believe this model is in the US as a L175. Am in need of a WSM for this beast as need o correctly check clutch adjustment and probably end up needing to replace the clutch.
I have looked on Kubotabooks.com however don't see anything similar. Any and all help appreciated.
Boo
MX5800; BH92, BB2572, Forks 3048
Jul 1, 2016
123
HOLT, Florida
I bought a WSM at the same time I bought my MX5800. The book was $120.00. However, I do believe that it will become more valuable as time goes on - to me, anyway.
5,515
2,226
Interesting story that goes along with this.
I had a guy come in and ask me the torque spec, the sequence, wanted the valve adjustment procedure and cam timing procedure. I started to tell him, but decided that he'd probably forget half of it by time he drove home. SO I suggested for him to buy a service manual. He told me to download one and give it to him. Nope. That information is available to dealer personnel but it's confidential and proprietary, and there is a watermark on the page. Dealers are not to freely distribute. That's we were warned of, and that's what I stick to.
Guy standing on the other side of the counter got mad and said he'd go buy a John Deere. Cussed me 10 ways from Sunday too. But that's the type stuff that you deal with in the industry. You're the bad guy if you do right, and you're the bad guy if you do wrong. You don't win.
  • Sad
7,639
Lugbolt, principles are things you do because you believe they are right. It doesn't matter who is watching, who is listening, or what the results are, you stick to them!
That offends some people. Don't let their problem become yours!! You did good.
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
41
KY
Does anyone have a WSM for a B3200?
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
45
11,016
has anyone here used this link? is it safe to use? they do take PP.. so guess could get money back that way if its a scam.
If your looking for the manual for the B7200HST go to kubotabooks.com and download one for free.
If you need others and that site has it, yes it's a safe site! ;)
sdk1968
Oct 19, 2016
929
45
got the WSM's that you guys posted.. no problem...
then today i picked up an B6200 & B7200 OPERATORS MANUAL...
havent seen that posted here, so if anyone needs the OM?
i'll post it if thats allowed.
sk
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
I'm sure kubotabooks.com would love a copy too.
