Hey guys
Picked up a used Frontier GM1060R for my L185, it's got Woods stamped on the gearbox.
Deere has it listed as rated for 15 - 40HP, so my 17HP L185 should handle it alright.
I'm a little curious about the chains running down from the top link
Most other finish mowers have solid bars, the chain seems a decent idea as it allows the deck to float a little better.
What's the reason most run solid bars? Cost wise it wouldn't seem to make a big diff.
I flipped the two front wheels so they're not as close to my rear tires, do need a shorter top link...
I mowed a small overgrown field in 3rd (low), did great -- esp considering the blades could use sharpening/replacing.
Tractor didn't bog any, though I def. need weights on the front. With the mower lifted in the air the front wheels were rather floaty. Anyone know roughly how much weight I need? Mower has a listed weight of 600lbs...
Also wondering what gear others mow in,
Guess I'll figure out via trail and error where the tractor is most happy and the mower is still able to maintain a decent cut.
![](http://i.imgur.com/lwhBnFM.jpg)
![](http://i.imgur.com/kCy2zb3.jpg)
![](http://i.imgur.com/ZHlSL5r.jpg)
