Water proof storage box L 3940
Hfrs7
Grand L 6060 --- ZD 326— GR2120—BX2680
Nov 2, 2014
44
Alabama
I made the mount using 10ga steel. I welded 3 braces on the back, notched out for the ROP's and drilled holes to mount. I mounted it to the 4 existing ROP's bolts. The box is an ammo box mounted with 4 bolts and rubber washers. I made the washers from a piece of horse stall mat and a 1 1/4 hole saw. I re-positioned the reflective triangle bracket. I lined the box with outdoor carpet. All the parts were painted using Kubota grey paint. I used scraps so the only cost was the stainless hardware and paint.
3,051
Nice work !!! Looks like a excellent way to mount a tool box!
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Like the carpet, but on mine I use rubberized undercoating, just spray it in, hose it out, if it gets dirty...:D
bmblank
Mar 4, 2015
774
494
Cadillac, MI
I'm surprised nobody has mentioned concerns over drilling into your ROPS. That seems to be a hot-button issue around here.
Hfrs7
Nov 2, 2014
44
Alabama
I did NOT drill into my ROPS. I would not do that. I used existing mounting bolts only.
ShaunBlake
B6100D; B219; Piranha bar; Hodge stabilizers; Filled Ag rears; R322T w/48" deck
Dec 21, 2014
899
Sugar Hill -- next door to Buford, GA
Really nice, Hfrs7, I'm inspired as well. (Not to make a metal toolbox; mine will be plastic. I'm actually inspired to get you to "run over" and do some creations for me! :D)
That mount looks hefty enough to stand on -- what is your intention for the open space, any plans?
bmblank
Mar 4, 2015
774
494
Cadillac, MI
Aha, that would explain it. I didn't realize there was anything down there. It definitely does look beefy. I wish I had room on mine for something like that.
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
That's quite the mount...you could put a ball hitch on that thing and tow a 40 ft motorhome. :D Very nice fab work!
Hfrs7
Nov 2, 2014
44
Alabama
I originally wanted to put 2 ammo boxes in that space but I did not have enough room between the ROPS. I thought about a small drink cooler holder but I haven't decided.
Hfrs7
Nov 2, 2014
44
Alabama
2 will fit on there but the latch will not have enough room to work...
