I have been looking on-line for gray parts for a L1500DT
and have not found much, is there a list of sources available?
Thanks, Bill
Thanks, Bill
Good question rmasonjr!I need some odds and ends parts for a ZL1501 - do you have a parts/price list online?
Go to www.kubotabooks.com if you haven't done so already. And download the parts manual for the l185. 90% of the parts on that list will work for the l1501. It get's a little hazy with the gears. But everything else is the same. Then you can pull the parts manual up on your computer, jot down the part numbers you need and then order through colemans, messicks, or your local bota dealer using the part numbersI need some odds and ends parts for a ZL1501 - do you have a parts/price list online?
Here's a couple of old threads that should answer your questionsI am looking for tines for a b7000 tiller and a 3 point hitch assembly.
Hello AndrewHi
I have a Kubota L2002 that need a rear axle housing which other tractor can work L235 L245 or the l275
