Hello. I have a B6100 and have noticed over the last few weeks that the brakes are weak. How are the brakes adjusted?? Not sure what I'm getting myself into, so any and all help will be appreciated!! Thanks
What model (D; E; or HST)?Hello. I have a B6100 and have noticed over the last few weeks that the brakes are weak. How are the brakes adjusted?? Not sure what I'm getting myself into, so any and all help will be appreciated!! Thanks
Kubotabooks.com does have the WSM, it's a three part download.I believe Kubotabooks.com doesn't have the WSM for the B6100, and you will need that if you have a brake issue.
I've downloaded the 3-part PDF (but deleted it) and "thought" I'd gotten it at KBooks but can't find it. The link in the OTT archive takes you to the Owner's Manual section, and there are two WSMs in that section, but only WSM L210.pdf and WSM L3200.pdfKubotabooks.com does have the WSM, it's a three part download.
Try unlocking the brake pedals, then use the left and right brakes independently and see if both are about equal in stopping effectiveness. Your problem is with the brakes themselves, not the adjustment (which only "balances" the two pedals to engage the brakes at the same time).Okay, sorry... I have a 6100D. The issue I am having is when I press both brakes, the tractor is slow to stop, also the E-brake will not hold the tractor, I have to lower the FEL and raise the front wheels to guarantee stopping movement.
http://www.kubotabooks.com/AutoIndex/index.php?dir=Tractor Owners Manuals/I've downloaded the 3-part PDF (but deleted it) and "thought" I'd gotten it at KBooks but can't find it. The link in the OTT archive takes you to the Owner's Manual section, and there are two WSMs in that section, but only WSM L210.pdf and WSM L3200.pdf
I've looked in several sections, but no joy. NIW, do you have a link to the files?
