BX
7,255
in about 10 years. :D
When and If it starts to have blow-by you'll know it, then it's time to either rebuild or replace.
Is it having any issues now?
AlexHutton
Kubota BX2660
Feb 15, 2015
21
Sperry
Well, no not to my knowladge, but I dont exactly know what the symptoms are when it becomes a problem, the thing that scares me is the engine specifications at the Kubota Engines Website has my engine lifespan of only 3,000 hours, and I'm nearly almost at 1,200 already so thats why I'm wondering?
6,958
I wouldn't worry about the 3000 hour mark on your motor and it's toast. I have similar sized kubota motors with 10,000 plus hours on them at work. Haven't had any major engine issue. Just the occasional fuel selonoid, fan belt, or injector.
7,255
I would say there "estimate" of engine life span is severely under rated, I guess that saves them some abuse down the line.
Also of the 1200 hour that you've clocked, how much was actual use, and not just idling in between work. ;)
ShaunBlake
B6100D; B219; Piranha bar; Hodge stabilizers; Filled Ag rears; R322T w/48" deck
Dec 21, 2014
899
Sugar Hill -- next door to Buford, GA
North Idaho Wolfman;130032 Also of the 1200 hour that you've clocked said:
Hey! I'll have you know, there is a *lotz* uv work gonin on! Ah gotz tuh git down n tip de rokz inta d buket det ah kaint git de loader under, den git bak on n tip d buket, din try tuh skoop up s'more rokz, din git down n dew it all over agin. <whewh> Ah think ahm dewin more work now den b4 ah got dee Kuboter!
3,587
Lmao,,,,, :d Sorry my friend I just couldn't pass that up
