L 245 engine
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum from Alabama. The pistons you took out are too big, or are the ones you are trying to put in are too big?
5,594
jd, you just trolling through? You just made a ridiculous statement with no question so.....probably so.
jdharris
l 245 tractor
Feb 9, 2015
wheeler texas
this is the first time ive done this so bare with me the standard pistons i bought from kubota are .006 bigger than the ones that came out of it. even without the rings they wont go in the sleeve. kubota says thats the only pistons for 1115 cc engine. i read this might not be a kubota engine but it says its 1101
6,438
Ok I think I might have the answer for you...
I'm betting it's not .006 it's .060 and unless you bought the sleeves to match it will not fit.
I've never heard of pistons only being oversized by 6 One Thousandths.
But 60 One thousandths, yes.
How did you determine that you needed oversized pistons?
If it's a Kubota tractor it's a Kubota engine, look on the side of the block right behind the injection pump and hydraulic pump there will be the cast in CC's of the motor, it should read 1115cc.
