Tachometer not working
Bille
M5700 4wd/loader
Feb 9, 2015
Magnolia, texas
I have a 2003 M5700 with ROPS. I was using my tractor to run a log spitter and the second day, my tach quit working. I have a repair manual from WSM and I can not find anything on the tachometer. Is it electrical, mechanical, where do I start troubleshooting?
6,438
It's a cable tachometer.
It connects in front of the injection pump on the gear case.;)
Bille
M5700 4wd/loader
Feb 9, 2015
Magnolia, texas
Thank you for the info. I will look at the cable and connections, what is the typical problem, a bad cable?
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum Billie from Alabama.
6,438
Typically the break the front gear drive, not too expensive and super easy to replace that part. ;)
6,438
On advantage of the larger models, they tend to leave you a little more room to work on things, but not always.
Bille
M5700 4wd/loader
Feb 9, 2015
Magnolia, texas
Pulled the cable and found it to be broken maybe an inch past the connector near the pump. Will have to order a new cable. Thanks for the help. Also glad I took the dash off, found the pivot bolt for the shuttle shift ready to fall out. That would not have been good out on a job!!
oldbeek
B8200d with loader
Jan 28, 2015
lancaster CA
The tach drive does not get oil from the engine. I would lube the drive with motor oil while the cable is removed. No lube in the drive is why they fail, in my openion.
