Correct Tube for 27x10.50-15 tire?
L35
Jun 13, 2010
520
422
CT
Can someone point me in the right direction for some tubes for the front tires on my L35? I would like to make sure the stem is in the correct location it seems like there is a lot of variations out there. The tire size is 27x10.50-15 and it has the metal style stem installed currently.
Thanks
L35
Jun 13, 2010
520
422
CT
I saw those when I googled the tire size but wasn't sure if they would work with my rim. Thanks for the recommendation
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
302
northern lower Michigan
Most tubes are combination sized and yours would be a
27x850/950/1050-15. Most all that are sized that way have the TR15 or
TR15CW ( CW=chloride/water ) rubber valve stem.
In my experience ( I sell tubes for a living ) the best for a 27x1050-15
is actually the 11L15 ( or 11L15/16 combo )because the combo runs smaller than what's needed on the wider rim that you have.
That size is actually a tubeless tire and most of them unless it's needed due
to a repair really aren't required.
Al
L35
Jun 13, 2010
520
422
CT
I did order 1 of the tubes that was listed in the link. It's the combo tube (850,950,1050). I have a small cut in the sidewall I can't successfuly patch, so I'm going to a tube. Thanks for the reply.
6,599
Take an old tube and boot the cut area, if it's a big cut it wouldn't hurt to put a couple of patches over the hole to protect the tube. ;)
L35
Jun 13, 2010
520
422
CT
Roger wilco
L35
Jun 13, 2010
520
422
CT
Well about 2 months later I finally got this tube installed and it fit well, valve stem worked out well, hopefully no more flats for a while:cool:
