I am a new owner of a used L2550 for the last couple of months and it has been running and starting fine until this morning. I'm pretty sure it has something to do with the ignition switch, but I wanted to seek some more advice first. When trying to start it this morning, I tried to turn it over, but nothing happened when I turned the switch. I tried again, and then it started turning over very slowly and then I turned the key to the off position, but it was still trying to turn over on its own. It continued this way with the key completely out and the switch in the off position. The battery is brand new (3 weeks old). I assume it would be smart to replace the ignition switch, but is there something else I should look for/at? I'm not too mechanically inclined as well (see screen name), but I think I could do an ignition switch if that's it. If so, would any tractor parts supplier have this part? It's a 1991 model. Any help is appreciated. I'm new to farm and tractor life and need it up and running again soon. I'm in PA and it's pretty cold. TIA.
