L4150 remote
flattop
L4150
Jan 7, 2015
LA PORTE indiana
New to forum, just bought a L4150, serial # 10029. I am looking for a hydraulic remote add on, either a kit or control valve. Kubota does not offer one anymore. Either new or used is fine, thanks, Flattop
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Any competent hydraulic shop can do this, or the dealer.
If you already have an FEL, you can usually get some kind of power beyond setup going that does what you need as well. You can try Ebay for an aftermarket kit or call Surplus Center and they can usually help build one up for you to install.
Jooleus
To flattop,
Not sure if you are still on this forum, but I am wondering if you ever managed to get some remotes installed on your L4150. I just picked up an L4150 and am facing the same challenge. Did you find an aftermarket valve that would fit? Would appreciate any insight you may have on this topic. Thanks!
Jay
Fl Bill
L4150 w bf 900 loader and L4440 backhoe
Feb 27, 2022
Florida
To flattop,
Jay
Jay, did you get the power beyond and 3 rd function going on your 4150. Same boat here, like to do the front and add a hydraulic top link.
6,550
That exchange was two years ago. Adding remotes to that tractor is trivial. What does "want to do the front" mean?
6,550
3 function on the loader for an auger.
A third function valve is typically mounted on or near the loader valve. There are "universal" kits for kits for installing a pushbutton operated electric valve. They provide the basic pieces but you have to do a little fabrication to mount them on your particualr machine:
Another option is to use a much less expensive manual valve. I would consider it a better solution for controlling something like an auger. You can also add moire than one spool and use the additional spool(s) for rear remotes. It could be mounted on the loader or the fender like the OEM valves. If its on the fender it would remain with the tractor should you remove the loader.
