kubota l245dt what is this lever?
Kubotal245dt
Germany
hello i'm new here and i live in germany. first many thanks for the recording in the forum you have already helped me with some things that i could read here. i have a l245dt and now i have seen on the internet photos of another who before the pto lever still a small lever. i did not have the lever. what is her function? for what is he?
(sorry for my english :D )
6,870
I have that lever on my L1501, it's an extra hi/low range. They call it a creeper gear. You can gear the tractor down where it's super slow
Tooljunkie
May 13, 2014
4,150
As darren mentioned,i also have that lever. Gives an extra low range. The housing below lever should have H and L cast into it.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
If you look real close at the housing, you can see the lever is in H, in the photo.
Shift both other levers to N, and you should be able to easily shift it to L. On my L12202, I have an aux transmission by my left elbow, that has 4 speeds on it. If you are in 1, you can get off the tractor, and go get a cup of coffee, drink it, come back and the tractor may have moved 20 feet, or so!:D
retiredlawnboy
M6800, L245DT, L245H, Gravely 816T with Cab and Wing Mower, 5665, 1960s Li
Nov 24, 2014
Danville, OH 43014
Just to clarify, this lever is in addition to the Hi/Lo lever below the left seat? I have owned and seen many 245s and never came across this feature.
Tooljunkie
May 13, 2014
4,150
Yes,lever by seat in low, transmission in low range reverse ,i step off and look around while backing up a trailer. It moves very very slow. Handy.
7,117
It was a creeper function for rice patty work and some US models were equipped with it for trenching work. ;)
That's is why it is more common to see it on Grey/Gray market tractors.
retiredlawnboy
Nov 24, 2014
Danville, OH 43014
That is very interesting. Not to be critical, but what would you actually ues this lever for? I would not think the manufacturer would design so you could get on and off a moving tractor! I will admit I too dismount from mine in Lo 1st when laying plastic or cultivating and pick up a rock too big to pulverize but any slower than that just seems as if you would place in neutral and restart.
retiredlawnboy
Nov 24, 2014
Danville, OH 43014
I see Wolfman had answered and your post had not showed up on my screen. Trenching would make seance.
Alexisferos
L-1501 DT
Oct 24, 2013
245
Greece
lot of useful usages of the creeping gears,
you can read this old post here
you can use all the power of your engine at the tires and the pto...
