4WD working properly?
11,039
Wow... and Yes ouch!:eek:
If you did your own work you could save about $400 in parts and a ton in labor, but it's a pretty good sized job.
Try west Kentucky Tractor Parts and see if they have a good front end.
http://wkytpstore.com/
Benhameen
2012 Kubota L3800 HST W/FEL and 1963 JD 2010 row crop utility
Jan 27, 2013
713
136
Southern IL.
That quote will make you keep your axle oil changed and weight on the 3pt for sure. good luck...how many hours are on your tractor?
Benhameen
Jan 27, 2013
713
136
Southern IL.
Sorry, I see you posted the hours in your first post, my bad.
westx
M5030DT
Dec 17, 2014
31
Dayton, TX
I pulled out the tie rods and some of the unnecessary items (how do they get away with selling a $160 L-shaped bracket???)
I'm down a couple thousand from where it was, so I'll have to pull the trigger on that.
First order of business: ballasts!
