I have a bit of a mongrel tractor. And it's got a broken crankshaft. Looks like my best option might be to repower with a new engine - problem is finding out what to use to fit it.
The problem is
1) It's an L1501 from the transmission backwards (L1501 - S/N 12875)
2) The engine is a 3 cylinder, with 1115cc stamped on the side, which suggests a D110x engine.
3) The injector pump serial number is Z750-48645. This suggests that the 2 cylinder injector pump has been fitted to a 3 cylinder engine.
4) I can't seem to find anything that identifies the engine block any better than that.
So the question is - how can I find out what engine to use to repower?
1) Should I looks for a D110x engine and hope for the best
2) Should i look for a Z750 engine (original for the L1501) and hope whoever changed the engine over didn't modify anything.
3) Could I even go with a modern D1105.
What do i need to know to figure out if a new engine is going to fit.
1) Bell housing mounts?
2) Flywheel specs?
3) Engine mount specs?
4) Manifolds (assuming new engine doesn't come with them)?
All help would be much appreciated.
The problem is
2) Flywheel specs?
