B26TL stalls under load
M1ke
B26TL
Aug 3, 2014
Schenectady, New York
My Kubota B26TL has 242 hours; it starts & throttles up & down but stalls when I try to move forward or reverse. I replaced air filter, fuel filter; have pressure from fuel pump mounted on engine block; no apparent water in fuel; I bled air from injectors & each cylinder is firing. I'm in a remote area and not easy to transport to dealer. Any other suggestions to get me going?
2,295
Any way the brake pedal is locked? Is it HST or gear driven?
2,295
HST. Free wheeling - no brake lock-up. It rolls freely in neutral
DO all the other hydraulic "things" work as they should? bucket? MMM ?
did you replace hydra filter? fluid at right level?
dmanlyr
L3200, Hustler Super Z
May 30, 2012
330
Graham, WA
Operator presence switch on the seat bad? That would cause it to shutoff when activating the HST pedal.
David
