I bought part number 67810-76100 which is the hyd pump for a b8200 after reading about others on here having no problems. It does NOT FIT!
The dealer will not take it back due to it being a special order. I don't know what to do at this point as it will be $450 down the drain.
The in/out ports are opposite the stock pump and I'm pretty sure that will make the pump turn the wrong way for me to use it at all. I was going to cut my steel lines up and make it work but not sure that it spins the right way or if that is possible.
What a disaster.
Any help will be appreciated.
What a disaster.
