Can't decide BX1870 or 2370 for mowing
tomd999
Mostly Deere tractors, only Orange here so far is Gramps Allis Chalmers
Jul 19, 2014
Manchvegas, NH.
Hiya,
I'm off to the 2 orange dealers this morning to see which one will give me better prices. But I keep going back and forth between the 1870 and 2370. I'm getting this to replace a 25yo garden tractor to mow just under 4 acres of hilly lawn. This will just be used to mow the lawn and maybe do a bit of york raking from time to time. (with a 6 foot rake I already have)
So my questions are:
1) Does the 1870 have the torque to run the 54" fine cut while going up moderate slopes?
2) Will the 1870 do the above with a bagger on the back?
3) With the difference in tire sizes, is there a difference in 3pt height that would affect using a rake or blade?
4) Are they different chassis because of the different overall length?
5) Should I just go with the 2370 and not look back? :D
Thanks,
Tom
koja
BX25D
May 27, 2014
335
Fremont Mi.
Go with the 2370. You won't regret going bigger. No such thing as too much power , but not enough power sucks .
Paulemar
BX25, 60" MMM, 3 point hitch, 60" front plow, 48" Phoenix rototiller.
Jan 21, 2012
112
Pittsburgh, Pa
It has been said before many times in one way or another. There are few people that complain about having bought too much tractor, but there are many that wish they had bought a bit larger. Get the 2370! When it's sitting out in the middle of that 4 acres, it's not going to look very big. It's also not going to feel very big after a few rides when compared to what you are used to with the garden tractor. Do not feel intimidated by the size difference when compared to the garden tractor. Get a loader and ballast box too. The loader is probably the most useful thing you will ever buy for the tractor. It goes on and off very easily on a level surface. Also consider the 60" mower if you go with the 2370 unless you have a lot of obstacles.
4,679
In MHO,, tractors are like motorcycles,,, I don't know anyone that has ever complained about being able to go to fast or having more power,,, 2370 my friend and you will not be disapointed
Polishammer
37
Atlanta, GA
I have to agree. Like you I was looking for 1870, but ended up with 2670.
Side by side even though the specs are slightly different both machines look the same. 2370 has the same frame as 2670.
More power never hurts.
Now, comparing to a standard garden tractor, the BX is much larger, but things change once you clime aboard. Oh, and with the power steering BX is easier to get around than my old garden tractor.
2,970
Go with the 2370......you will never regret it
tomd999
Jul 19, 2014
Manchvegas, NH.
Hi all,
Well, went to the dealers today, prices are close, attitude is pretty poor at both but slightly less poor at the closer, but higher priced place so I guess I'll be going back there.
They had a 1870 and 2370 parked side by side. There is a noticeable difference in height and length. The operator station floor is slightly longer and the chassis sits higher, no doubt due to the larger diameter tires. I'm going to go with the 2370 for the larger tires mainly but the HP is nice too.
Thanks for your opinions and to the people that suggested a loader, This is just a mower, we have a utility tractor with loader.
Tom
4,679
Oh my oh my oh my,:rolleyes:, just a mower,, my friend you aint got no idea what that little tractor will do and is capable of. trust me it is a lot more than a mower,,lol;)
MXBX
153
Maryland
Congrats on your decision! I'm amazed at how useful my BX2360 is. I strongly recommend the FEL, in fact, I use it as much or more than the mower. There are just so many things you can do with it. Also the Piranha Tooth bar for the bucket turns your little tractor into a beast.
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
Ain't that the truth , skeets... Behind my bx is 2 large trees and 2 small ones on the ground. Within the next 2 weeks, my bx will move every limb and trunck to a burn pile. Probably 5 to 6 thousand pounds of weight, and I will lift only a very small part of it, light brush.
tomd999
Jul 19, 2014
Manchvegas, NH.
Hiya,
Yes, I know the little tractor that could can do a lot with a loader. Just wondering if the initial 2K+ up front is worth it for something that will most likely sit in the barn for most of the time as it only has a rating of about 500 lbs where the utility tractor loader is rated for about 4500 lbs and the forklift we have in the garage is rated for 6K.
Tom
Sing
GR2120, LS J2030H
Jan 16, 2015
Syracuse NY
I am coming in on this conversation late, but the question is a curious one indeed.
I find myself in the exact same situation. Well, maybe not exactly as I have another tractor that does loader and PTO work. But I have similar acreage and similar sloped terrain to the OP. I came home with a GR2120 last spring (Fourth in a line of tractors in a progression of upgrades in quick succession). I was not happy with the transmission in the GR and now I am looking to upgrade once again. Due in part to the trauma of so many swaps in the past 3 years, I have pretty much decided to go with the BX2370 over the BX1870, but also because of reading many forums like this on the topic, and on my dealers advice.
But there are questions begging to be asked here. All advice from every quarter is saying go with the BX2370. My dealer gave me this advice not because the BX2370 was particularly better suited to my needs, but based on the fact that the BX2370 simply has more power and a better resale value for not a lot more money. Why better resale? Simple, the BX2370 has more power, and can do more with the loader, and with PTO powered equipment. TBH, the BX1870 might in my case do a bang up job of just mowing my lawn, which is exactly what I am looking for. The difference in my story is that I have an LS J2030h to do all of my heavy lifting. So I don't really need a loader on the Kubota, or the 3 pt hitch for that matter. The BX1870 seems like it would be particularly well suited to my needs. But is it?
There is nothing between the GR2120 and the BX series; therefore in upgrading to the BX I am getting loader and PTO capabilities no matter what tractor I go with. So is gimping the power and torque, and going with a smaller lighter weaker frame worth saving $1000-$1200? The choice between the BX1870 and the BX2370 is not the same kind of choice as between the other 3 tractors in the BX series is it? Think about it. The choice between the BX2370 and BX2670 is HP and torque, pure and simple. “Do I NEED more power, or not”? Or the difference between either the BX2370/BX2670 and the BX25D. “Do I NEED a Sub Cut set up specifically for a loader and backhoe”? These are choices that one can rationalize. But what is the story with the BX1870? It seems to me that there is just not enough distance between the BX1870 and the BX2370 to warrant a decision in favor of the smaller version. What can the BX1870 do better than the BX2370? One might be tempted, as I was, to think that the smaller frame on the 1870 would lend itself better to mowing. But the size difference is not THAT MUCH. It’s not as if the BX1870 mows circles around the BX2370. It may at best have some slight advantages in some cases. But is that alone enough to warrant going with the BX1870? A slight mowing advantage and $1000-$1200 in savings? But when you are spending $11000 on a tractor, is the difference between $11000 and $12200 really a clincher? We are talking a few dollars on the loan payments. On the other hand, the trade offs are significant. Resale value alone is much better on the BX2370 for obvious reasons. With the possible exception of mowing in certain cases, the BX2370 is simply better, and not by insignificant amounts either.
Why would anyone go with the BX1870? No one anywhere that I have talked to has advised me to go with the BX1870. So who is the BX1870 built for? What is the market demographic? When or in what situation would a BX1870 have such an advantage over the BX2370 that it would justify choosing the BX1870 instead?
For all intents and purposes, the BX1870 seems to be geared towards someone that wants the most frugal, lowest cost machine possible. But by every account I have read, and every person I have talked to in person, the general consensus is that the BX1870 is ultimately a disappointment, failing at making the “Savings” worth the tradeoffs.
I have given this a lot of thought, and my decision to go with the BX2370 is based not only on others advise, but that which I think I know based on experience. I do believe that the BX2370 is the better choice. Better for resale, and if you are going to have the loader and 3pt hitch capabilities, why would you NOT want more HP and torque and larger stronger frame to properly support it? Chances are, my BX2370 will never have a loader on it. I may use the tiller on it just because I can. At the end of the day, as a lawn mower, the BX1870 may do at least as good a job as the BX2370. In some cases, it might do that job ever so slightly better. But is that enough justification not to get the 2370? I don't think so.
Should Kubota axe the BX1870 from the line up? I am having trouble seeing what its niche is. The BX1870 seems like it would be a fine tractor, accept that there is an even better tractor available that you would be crazy not to go with. No one, especially the dealers who actually have a dog in the fight seems keen to sell the BX1870 to customers. I can’t help but think that the BX1870 is a dinosaur that somehow managed to survive to modern times. Like the BX1870 was where the Sub Compact market technology was 20 years ago, albeit with some extra polish. Somehow, its existence does not make a whole lot of sense.
Thoughts on the virtues of the BX1870?
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
I found a niche for my 1860, in fact I really don't understand why anyone would buy a 2370. Power has never been an issue for me on the hilly 6 acres I mow with the 54" mid mount. It hasn't been a problem removing snow or lifting dirt.
The chassis of a BX simply isn't big or heavy enough to justify more power PERIOD in my opinion.
Yes you can lift a bit more with the FEL, but really you dont want to because the narrow chassis and light weight makes a max load carry sketchy as it is. To me, it's a waste of money to put an extra 5hp in a chassis that cant take advantage of the 18 hp it has. Kubota thought so little of the difference that the hydro pump and whole rear end assembly is the same in both.
If I could have walked out with a 2370 for the same money, I'd have picked it but by no means could I find a way to justify spending more for a machine with generally the same capability.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Sorry, but my experience with tractors is different. Have a 27 HP blue, 18 HP blue, and a BX1860. The 18 HP tractors do practically everything I can do with the larger one, except of course the limited bucket lift, etc. for the BX.
The BX has never bogged down due to too much drag on the mower, etc. I had expected to see limited usefulness, but that has not happened. I run the RPM up when necessary since that is where the power is. If you are satisfied with near idling RPM for all your jobs, then go larger. Of course then you will have lower HP even for the big ones.
tcrote5516
Sep 2, 2014
482
Cerlawson, thanks for backing me up. I thought I was going to be out on that limb alone:eek:
It's good to hear from someone with both the 18hp and a larger machine since I came to my conclusion based only on what I've seen with my 1860. The 18hp really is a great power match for the chassis size and capability.
To add one more thought to the OP on resale...I would save $$$$$ and get the 18hp vs the 23 and put that money into the FEL. Even if you never use it you will get more money reselling a BX1870 with a FEL than you ever would selling a BX2370 without a FEL.
cerlawson
Feb 24, 2011
1,067
PORTAGE, WI
Me again. The 18 and 27 HP blue tractors each weigh about 2300# bare and I see very little difference between them for plowing deep snow in Wisconsin, via rear blade. 18 HP is plenty. The 18 HP Orange BX weighs roughly 1300 bare. Then with a 5 ft. rear plow the BX does about as well as those larger guys, sufficiently so that I am satisfied with it. Resale never bothers me, because my experience with several tractors is that I have sold at higher or equal price than I paid originally. I never bought figuring on selling.
GBPackerFan
Appleton, WI USA
I'm considering the 1870 because of the -3 inches in length and the 48" deck. I only mow about an acre but the 48" would be perfect for my landscaping configurations.
Right now I have a Simplicity Prestige, 30hp. Great mower and I do blow snow with it...does a good job. However, it is a belt drive tractor and everything I do I need to switch out belts and subframes. I want a tractor...a real tractor...that can do real work. I would use the FEL. I would use the snowblower. I would like the PTO rear bagger. And the 1870 is about the same size as my Prestige.
Concerns about HP are there, for sure. But I need to get over that. I need to think that a gasoline belt drive tractor loses a LOT of HP through the belts. And the higher HP only comes at the highest RPM.
The argument about resale is a valid point. There are a number of dealer who don't even stock the 1870 and push the 2370...which is a still a small machine. But a guy needs to take the resale argument into consideration and if he plans to keep the tractor for 10+ years then it is a moot point.
4,679
I aint never heard anybody complain about to much power,,,, just sayin
1970cs
1,124
Grand Ledge
The BX1870 will run out of power in tall grass around 7" high gear, loader on with a 54" deck. If you keep things in check that 48" should be a walk in the park!
The only thing is that the Prestige quality of cut is second to none. Do you stripe with tractor?
Pat
