I recently lived the nightmare of having my Xmission oil pumped in to my engine due to a bad oil seal on the engine operated hydraulic pump. I have the pump off but there is not a snap ring holding the oil seal in place as my manual shows. There is a snap ring located on the fuel pump that appears to be holding a bearing in place but not on the Hydraulic pump oil seal side.
I noticed on my Hyd pump, it appears that a punch was used to indent the metal on the pumps case around the oil seal in order to hold the seal in place. I don't want to proceed until I have a better idea what to do. This is an older B7100 4x4 and not a hydrostatic.
Thanks for your help
IBNFE
Just wanted to update my Post.
Seems there was not a snap ring installed by the prior owner. I received my new parts today and was able to determine that the oil seal was pressed in and that the pump does not have a groove for the snap ring to lock in to. So I removed the old oil seal with very small common screwdrivers being carful not to damage the mating surface. Once out I applied some assy fluid to the new oil seal and pressed it in as far as I could get it by using a socket of the same circumference Lastly I used a soft hammer to seat the seal and then realized that there was just enough surface to install the new snap ring I ordered. I then seated it with the same socket as mentioned before.
IBNFE
