brand new and dead
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Check the cables on the battery. When running,the heat of the engine will warm things there and a marginal connection can expand and open and thus "no battery". While you are at it clean the terminals and the inside of the connector. Of course other possibilities are there, but try this first.
muffins
b3300
May 9, 2014
berkley ma 02779
she has juice
the ignition lights come on
but motor does not start
does not even crank
it was running
i was moving the seat from back hoe to drive position and the motor cut out.
wondering if that is related to motor shut down?
or coincidence
Donystoy
Dec 10, 2013
566
217
Binbrook, Ontario
If this is a brand new tractor I would not do a thing to it except call the dealer. If you play with it you can void the warranty.
Just read your last post, do you have a safety cut out switch under the seat that might be open. Use to call these dead man switches.
dmanlyr
L3200, Hustler Super Z
May 30, 2012
330
Graham, WA
I know this is basic, but have you read the owners manual to see what the procedure is for switching the seat around and what effect that might have on other operation, such as not allowing the PTO to be engaged with the seat 180 degrees turned around?
David
gpreuss
Oct 9, 2011
1,166
Spokane, WA
I can't stop thinking this has something to do with the seat switch. Maybe while turning the seat around you knocked something, or possibly even pulled the wires from the switch? Have a really good look around there.
Mostly we really enjoy our tractors. This is a bummer...
6,387
It's a seat or PTO safety switch that is either engaged or disengaged. ;)
Csxman66
Kubota BX25D,bushhog, box blade,rototiller.
May 3, 2014
15
Lake lure,nc
I know your pains muffins,12.2 hours on a brand new bx25d and in the shop one week after purchase.i wont get on here and say" boy I wish I had bought a deere,or massey"from what I hear,deere has gone down in quality and massey isn't doing much better.dont know what to do.when the bota is fixed and in my hands,its up for sale!! not going through this crap for as long as I own it,and im sure there will be more,id bet $$$$ on it.:mad:
6,387
Sounds like you just need to pay someone to do the job for you. ;)
3,317
Wish you better luck on your next,,, what ever brand ,,, you buy
Bluegill
Jan 11, 2012
1,560
Success Missouri
Usually if there are problems they show in the first few hours. After fixing, the rig is good for many years. You wont find higher quality than Kubota, but good luck with whatever you decide to get...
