7 shank ripper
JLMullins
L3800 Gear 4X4
Feb 25, 2014
14
TN
Does anyone know how to install a shank on a ripper? The springs are quiet large and was wondering if anyone had a good way to install? Thanks in advance.
Thanks,
Jimmy
New To Tractor in 2014
Last used 1979 before military career.
6,060
Picture of what your working on would help, there are a lot of ways they are attached to different models. ;)
Name and model # would help too!
JLMullins
L3800 Gear 4X4
Feb 25, 2014
14
TN
6,060
Is it putting the springs back on the pins that your having a hard time with?
If it is you can use a piece of pipe fit it through the spring and the end of the pipe over the pin pulling the spring onto the pin, put a little grease on the pipe so the spring slides easy. ;)
JLMullins
L3800 Gear 4X4
Feb 25, 2014
14
TN
Thank you, just needing a little help here and there.
Jimmy
Yes it is putting the spring back on and stretching it to the installation knob.
