HP Laptop
4,692
Anybody that has a freekin HP laptop with windows 8? The OL does, and the hard drive went south according to geek squad,,, don't ask how I feel about them,,,, anyway she bought the damn thing at Sams club who will not honor the return policy because its over 90 days, geek squad says the hard drive is fried and they will do the install for nada but the hard drive is going to cost 150 bucks, so I try to get in touch with HP bad freekin move,, They wont trust geek squads determination that the hard drive is toast and they want me to do dianogists on line with some freekin Indian or Hindi that cant speak freekin redneck!!!! And all day I have been getting the run around from one to the other and back to the beginning again... :curse: :curse: :curse: :curse: :curse: :curse: :curse: :curse: :badday: :badday: :badday: :badday: :badday: :badday:,, All I want to do is send it back for warranty work,,,and they wonder why I hate people most days
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
Hi skeets, yep been there with HP also, they used to make decent kit a few years back but now its all rubbish kit.
I am still using a HP pavillion laptop that is 5 years old, maybe older as it hd windows XP on it, works brilliant:D
just upgraded to vista and it works really well.
anyway, dont expect to much from them warranty wise on domestic user kit:( , hope you get it sorted.
rob
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
Okay skeets I see you are mildly pissed.
Is the laptop warranted by HP for one year? If so, follow all steps below, if not just repeat steps 1 & 2.
Step 1 - consume adult beverages tonight until problem doesn't seem so bad.
Step 2 - go to bed and sleep off the excessive consumption
Step 3 - wake up in morning and call HP, (after 3 cups of coffee) tell them you must speak with manager in English (they won't get redneck-speak).
Step 4 - tell manager you want it fixed, ask for RMA number for return under warranty.
Step 5 - if the manager won't do a return without trouble shooting, tell him you are illiterate, hard of hearing, and knows where he lives.
Step 6 - if all of the above fails, tell the OL she has a problem, then duck, then repeat steps 1 & 2.
4,692
DAYUM,, now I have to clean coffee off the screen,,,lol:D
The_Al
L3540, Heavy duty FEL, 9' bachoe, Brush hog, 72" grappler
Jul 19, 2013
154
MA
Skeets,
If it is not covered under warranty, then grab a cheap HD similar to:
http://www.ebay.com/itm/New-160GB-5...-Acer-HP-Compaq-IBM-DELL-Laptop-/160861262507
Do you happen to have restore "CDs/disks"?
Donystoy
Dec 10, 2013
698
336
Binbrook, Ontario
All joking aside. Call them back and tell them you want to speak to someone in the USA. They will usually honor the request.
Up here in Canada when asked for English or French I just ask for French. You are immediately re-directed back to Canada and they have to be bi-lingual and can speak English.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Now that's good to know... Thanks
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
327
90
Bagley, MN, United States
If you have another PC that you can access the internet, you can download a free hard drive diagnostics program from Seagate(it will test any brand but will only attempt to fix Seagate drives). You will download a file with a name similar to seatools.iso -- you also need a CD or DVD RW(ReadWrite) drive and one write-able CD or DVD. When you double-click the iso file a window should open - select the BURN to disk option. Let the operation finish - remove the CD/DVD from the drive and install in the CD/DVD drive of your failing PC and wait for it to boot the program from the CD. Click on the drive that appears in the list (if there is no drive listed - exit the program and reboot or CTRL-ALT-DEL - if it reboots a second time and no drive is listed then your drive is not being recognized by the operating system -BAD). Select the 'Basic' test first and then the 'Extended' - if you have a Seagate drive and it finds bad sectors on the disk it will stop with a list of the sectors and ask if you want them repaired(the drives have spare sectors on them that the software on the drive can swap with the failed ones). I have had pretty good success with this program. The attached URL also has instructions with it as well as the download - it boots up in DOS so it does not matter what version of software(OS - Operating System) that is loaded. I have run across a couple of configurations that would not properly display the 'control panel' to navigate through the program. Good luck!
http://www.seagate.com/support/downloads/item/seatools-dos-master/
4,692
OK I got the POS back from the geek squad ,, called the number in the book,, and hooked right up to New Delia,, oh joy of joys,,, Now this guy wasn't to hard to understand so I explained the whole story with pictures and arrows and 5 part harmony,, and he says vell I want you to take the back off the computer please,,, HUH??? der isa screw in de back take it out please... I said I don't have a screw driver,, he says,,, you don't have a screw driver???? Ah no!! Well I will wait until you get one, right about now I want to reach though the phone and choke him, Ya gota love the Swiss army knife, the small blade works grate OK its off,, now pull out the hard drive and disconnect the wires,, WTF? I cant hardly see in there and you want me to pull the hard drive and wires?? yes please I said you better makje sure that you have this down that you told me to pull this,, Oh yes sir it is,, lying little bastard , anyway I cant get it out I tell him that,, why cant you get it out he says,, GRRRRRRRRRRRRRRRR,, look let me talk to your boss,, OK so another push start gets on,, I go through all the same things with him tell him what the diagnostics were, the HD is toast, no I have to go through the same shit with him,,, Ok So now we have determined that the HD is toast,, he wants to send ME the HD and have me replace it WTF??? I said dude I cant get my fingers in there to pull it out,, OH are your hands that large? Ohh how I would love to show you, So after an hour and 45 minuets they are going to send me a shipping box to return it for repair,,, IF THEY FEEL THAT THE UNIT HAS NOT BEEN TAMPERED WITH IN ANY WAY,,, other wise I will have to pay
So as of this moment I am ready to nuke New Delia and HP tech support,, I figure that in about a month I should have it back
4,692
thumpa you been talkin to my OL,,,lol skeet shooting,, she has mentioned that several times, and being a prudent kind of fellow ,,that's why she does not have the combination to the gun safe,, :D
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
More HP problems.
Ever hear of Skeet shooting:D
ROTFLMAO
I bet those 12 ga. 3" mags would just about put it out of your misery. Do you need someone to launch it or can you adjust your clay pigeon thrower.
Sorry to be amused at your expense skeets... hahahaha!
4,692
Ahh hell steve if ya cant have your friends ease your pain with a laff whats the point,,lol cause that's what friends are for:D
aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
Well I'm not in India but still a long ways off or I could help you out.
I got an HP laptop from a guy I work with, it used to be his OL's. It was free to me.... maybe he was getting it out of his misery too. LOL :D:D:D
It is still an OL's machine. I fxed it and my wife is using it every day now. There were a few times I wanted to smash it with a hammer for all the frustration it was. I had to totally tear it down to replace some bad parts and get it going. Tearing down a laptop is a major ordeal. I don't recommend that for a fun time. :mad: If it weren't for the HP manual download that had all the steps in it I would have smashed it in tiny bits.
4,692
Well good news,,, I get the damn thing back and it works, though she has not had a chance to do anything with it yet,,,, Now since it was delivered Friday afternoon,, I have gotten anywhere from 15 to 20 calls from HP ,,, I should be ashamed but this was the last call
Ello my name es Sam and I am calling to see ef everything es fine wit your computer,,
Sam my ass you toweled headed twit,,, I don't know we just got it back and haven't used it yet,,,
very wiel you use it very soon, I call back and you tell me how it works, ok?
Who is this again,,,
phase,,,
dis is Sam,,
Is that like in Samuel?
yes dat es correct
OK sambo we haven't used it yet,
vell I have to know if es working
I plugged it in the screen lighted up so I guess its working
yes dat is good but I have to know it is working
Well sambo I don't know we haven't used it yet
very good you do use it and let us know
Sure will sambo whats your home phone number?
sir I do not have a number where you can talk to me
Well how and I suppose to let you know if tis working?
You call our technical support and tell them
I thought I was suppose to call them if it wasn't working
yes dat es true
So why should I call to tell them its working?
Sir I will call back some other time
OK sambo it was nice talking to you
OOK nice to talk to you too
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
phase,,,
dis is Sam,,
yes dat es correct
yes dat es true
ROTFLMAO!!!
skeets, you sure got a way with words, even Farsi. hahahaha.
