Hi all
Ive been rummaging around under the tractor, L1-22 about 30 year old and came across a few wires hanging down so had a bit of a fiddle and found they are attached to this unit which is more or less under the seat, attached to the side of the 3 pt tower
What is this?
A pair of wires goes to each end to like a couple of big solenoids.
The two hydraulic hoses just do a loop so the top and bottom hose are one and the same.
This
Cant see it in this pic well but on the end of the shaft of the 3 pt lift arm, there is a little lever and a rod that goes forward to the transmission.
Can also see the solenoid at the other end of the unit in the first pic.
What are these, does anyone know?
Cheers
Marc
What is this?
This
Cheers
Marc
