L245 throttle is sporadic
8,695
Both the start spring, and the throttle spring, are stretched and sprung.
I would:
1: Pull the pump out and make sure the rack is moving freely
2: Replace both springs after you know the rack moves freely or you'll just stretch the new ones out.
chartersj
L245dt
Oct 25, 2018
77
New brunswick, Canada
I got the wiring completed and speed control springs replaced but it is still acting the same. I have not pulled the injection pump yet but that will be my next move i just wanted to see if the springs would make the difference. I noticed when reving some I could sometimes see a tiny bit of fuel running down the side of the pump from the fuel rack pin. I'd say my problem must be in the pump. I took a little video...
https://youtu.be/tfO3C9HkUcI
8,695
Yes you need the injection pump rebuilt!
You should pull the injectors and have them tested too.
8,695
Ok can most diesel shops rebuild pumps and test injectors?
50/50 shot on that, call around. ;)
If you can't find anyone local there are plenty down here Oregon fuel injection would be my Number 1 pick.
chartersj
L245dt
Oct 25, 2018
77
Thanks I found a shop close to me that works on bosch pumps and will test my injectors as well. I have never removed a diesel injector is there any tips or anything I should be aware of before i attempt it? I see some motors require a puller to remove,,,do I need a puller? And I assume the injectors are located where the end of the fuel lines are from the pump....
thepumpguysc
267
Sunny South Carolina
There are 4 screws on the corners of the pump..thats it..
Yes the injectors are in the head, at the end of the steel lines..
Just remove everything in your way.. don't be afraid.. its just nuts & bolts.
8,695
You will need to have the rack in the proper location in order to remove the injection pump, there is a notch in the block that the rack pin fits through.
chartersj
L245dt
Oct 25, 2018
77
Thanks I got it out. To re-install you must be able to push it down to compress the plungers to get the bolts started? The rack did move freely but will have it rebuilt this week. Is it nessecary to remove the valve cover to remove the injectors? The nipples would hit the cover as I tried to turn them out
thepumpguysc
267
No, u don't have to remove the v. cover..
U DO have to remove the return line that's connecting each of them together,
Unscrew the nuts holding the return line on & carefully lift it off..
THEN unscrew the injector from the engine..
U REALLY should get a book.. Not that we don't like helping.. its just these simple things that are kickin your butt..
chartersj
L245dt
Oct 25, 2018
77
Ok perfect thanks. I do have a copy of the work shop manual which I have found lots of info on, however I agree I need to look at it more lol
chartersj
L245dt
Oct 25, 2018
77
I got my injection pump back from being rebuilt today and put it on. It seems better but the revs will still take off on it's own around idle. It seems fine at higher rpms. But then to bring it back down you have to bring the throttle back from idle position and almost shut it off. I noticed a tiny bit of bubbling around the base of the center injector. Could that be doing it?
